A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
#641
takin care of Business in
Received 4,732 Likes
#643
^^^ awesome....Betty has great taste IMO....
CROCS should be banned
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
rockstar143 (10-17-2013)
#644
Take it to the ramblings thread you nimrods
#645
Forgot to mention this....when i recently did my timing belt job, the acura tech that loosened my CP bolt, when i told him i'm doing the thermostat said "I wouldn't bother, on the 2004 and newer TL's, in 10 years I've repaired one that failed. They never do, just wait till it blows, which won't happen"
The honda tech that helped me confirmed on the Honda V6 accords she's only fixed one or two, said "yeah it's optional in my opinion"
#646
I have a 25 yr old Honda with it's original thermostat. Still works perfectly.
I have/had 5 Hondas total over the years and the only time I had to replace a thermostat was on a imported JDM motor swap. It was stuck open. I imagine the engine sat in a yard or warehouse for some time with no coolant in the hoses. This must have ruined the thermostat.
I don't replace them as "regular maintenance".
#648
^^^ might be a good idea to do it now since for the thermostat you will have to drain the fluid to replace the thermostat....
when you do the TB job, you drain the fluid anyway right, so might not be a bad idea to do it now, else you will either have to wait until the next time you have to do the job (another 105K) or if the thermostat fails (which is made clear that it might not happen)....
#649
#651
I'm actually considering changing out the top/bottom radiator hoses while I'm at it too...they seem flexible still and have no signs of dry rot but they're one of those things that tend to burst at the most inopportune time and they're now 10 years old.
#652
![No No](https://acurazine.com/forums/images/smilies/nono.gif)
they hold up just fine....I recently changed that to run a higher psi rad cap (which I never got to)...
if you want to change a hose out, look into the 2 hoses which take the coolant from the block to the TB and back....those had gotten "brittle" if you will....I swapped them out when I did the TB coolant bypass....
#653
Hoses are probably fine.
#655
^Agreed. If everything is going to be drained and apart why not spend that extra little for new and sexier hoses?
Are there quicker to open thermostats for the J?
#657
06 6spd TL BAGGED
was anybody recommended to change the oil pump seals? my acura dealership told me that it tends to leak and is a common problem so it should also be changed when doing your 105k maintenance. Another private shop that specializes in acuras told me the same thing...
#659
the overexplainer
cars are such unrefined machines in general, it's bound to leak one fluid or another.
nokiaboy808 (10-28-2013)
rockstar143 (10-25-2013)
#661
Do you guys recommend going above the timing belt and water pump? I was told nothing but those 2 items needed to be replaced, but everything else I see the tensioner etc is also replaced.
#662
the overexplainer
You're already in there, you might as well change them. They're a simple bolt on affair. Plus do you really want to trust those pulleys and bearings for another 100k miles?
ROBBIEVO (10-25-2013)
#663
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
btw, how much they want to charge you to reseal + tb job?
#664
Rob, as you can see from the DIY and from posts from other members, the other components were showing signs of failure. Judge for yourself.
The following 2 users liked this post by Majofo:
ROBBIEVO (10-25-2013),
#665
Ya kinda figured that, just wanted to make sure. Anything else I should be looking at? I just bought it last weekend. Probably gonna order new mounts as well.
#666
Definitely a good time to replace the side engine mount. As you can see, mine was destroyed. ![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
The auto tensioner for the drive belt might also be on it's way out. Mine is still running well, but there are few members here who eventually replaced theirs after going out of spec.
#667
Serpentine belt tensioner if you have a chirping noise in the morning.
#669
Hoff is going way above and beyond what he really needed to do. I assume partially because he was in extra deep because of the clutch.
If you're not doing the clutch a lot of that stuff, unless they are issues, don't need to be touched.
The following 2 users liked this post by maharajamd:
JJH (10-25-2013),
#673
^^^ i know rite
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#674
![Spanky](https://acurazine.com/forums/images/smilies/spankie.gif)
#675
First I've heard of that recommendation...and no, I didn't. No issues at 142K...
#676
For an extra $100, it's no brainer IMO (tensioner + pulley). My tensioner was fine, but others have found them leaking at the 105K service...
#677
06 6spd TL BAGGED
ho, long time no see braddah. The oil pump seal does leak. I didn't do a reseal on mine because I didn't see a leak but it is common. It's not like the seal will catastrophically fail and you'll be replacing a quart a week. If you do reseal the pump, get the vtec solenoid valve filter and oil pump o-rings. You can see them pictured in my kit (currently in a box in my garage) ![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
Majofo (10-28-2013)
#678
Haha yeah i barely come onto on here anymore unless im looking for parts or advice on something. I went along and got all the gaskets and seals replaced also. I got a good deal on the labor since i had my most of my own parts. Lets just say if i never know a couple of people that work at acura, it would have been a lot more lol
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
#679
Well, coming up on 3 years since I did my TB change and all of a sudden I get PS moan. Hmmm, I'm wondering if the O-ring went bad. I pop the engine cover and the PS reservoir and whole area around it are covered in PS fluid. WTF?
Upon closer inspection, I discover that the reservoir is no longer in it's holding bracket. I put in back in and check all the hoses and connections. Everything seems solid. Only after a power wash of the area do I discover the issue: There is a gash in the side of the reservoir where it apparently rubbed against the serpentine belt when the reservoir came loose from it's bracket. It had worn through the plastic just enough to leave a pinhole for the fluid to leak out of.
Lesson learned: be sure you firmly seat the reservoir back in it's bracket when you're done with the TB change. It might be a good idea to periodically pull the engine cover to check. I don't think I've had that cover off more than 5 times in 3 years...
#680
ouch..
