08 TL base alternator not charging battery
Old Apr 18, 2024 | 10:50 PM
domano 68's Avatar
Driving today and started getting all kinds of electoral gremlins, car hesitating, dash lights and barely made it home. Battery was at 12.7 V when the car was not running, but stayed at voltage when the car was running. Alternator? Maybe not?
I just had this alternator rebuilt locally last year though. So I am kind of perplexed here on what to do next. Removing this alternator and replacing is something I don’t want to have to do again. Very tight space!
I see there is 120 amp battery fuse in the fuse box under the hood. Should I check this fuse? Would this fuse being in the blown state actually prevent the alternator from working? Going to check the voltage tomorrow morning at the alternator itself. Anything else I can do or any other suggestions? Thank you in advance.
Old Apr 19, 2024 | 07:21 AM
cammark35's Avatar
alternator is most likely bad. voltage at the battery should be around 13.5-14v when the engine is idling.
It gets easier to replace with practice... you're pulling the passenger side radiator fan?
Old Apr 19, 2024 | 07:43 AM
twokexlv6coupe's Avatar
Alternator is going bad.
Old Apr 19, 2024 | 09:18 AM
domano 68's Avatar
Yes, that has to be done.
Old Apr 19, 2024 | 10:54 AM
domano 68's Avatar
Wondering if belt tensioner is going bad. Can you tell anything by looking at it with engine running? Would the speed of the alternator rotation vary - slow to fast, etc?
Old Apr 19, 2024 | 12:26 PM
domano 68's Avatar
Belt showing cracks. Replace? Bad enough to cause alternator issues?
Old Apr 19, 2024 | 02:02 PM
The belt is cheap and easy enough to try first. Even if you do wind up replacing the alternator, at least you'll have the peace of mind of having a brand new belt
alfadoctor
Jan 9, 2024 11:55 PM
asa32sd23
Sep 11, 2023 03:43 AM
Acura9915
Feb 24, 2020 01:27 PM
mr. robot-o
2G CL Problems & Fixes
Jul 14, 2011 07:21 AM
bryand178
May 12, 2006 06:45 PM
