Alternator fuses location
Old Sep 8, 2023 | 11:02 AM
asa32sd23's Avatar
4th Gear
I have a 2005 Acura TL, I changed the alternator, it's still not supplying 13.5 volts to battery. I assume maybe a fuse is blow, can't seem to locate it
Can anyone point me in right direction. Thanks
Old Sep 11, 2023 | 03:43 AM
PgLgGrg's Avatar
Pretty sure this means your battery does not have full capacity anymore. For a real double-check, You can go to autozone, get a new battery, try it on and see if the voltage is higher on the new battery. You can then return it and make your next decision. If it was a fuse problem, youd get no charge.
alfadoctor
Jan 9, 2024 11:55 PM
toshoku
Nov 26, 2022 08:59 PM
snoopgecko94
2G TSX Problems & Fixes
Nov 7, 2020 06:56 PM
Robmar26
Nov 23, 2013 03:13 AM
Sidecar
Jul 20, 2009 02:29 PM
