electrical charging system problem
Old Apr 19, 2006 | 12:11 PM
bryand178's Avatar
I got my alternator and battery tested, and they are both fine. I checked the main fuse and it is fine as well as the cgs fuse under the hood near the main fuse. Does any body know where the charging system fuse (#6) is? I think its the 15 amp one in the fuse box under the hood labeled cgs (or something like that).
I can jump start the car and it will run fine. But the battery is dead when I try to restart the car even after the car has been running for an hour with none of the accessories on. The battery is brand new and tested fine at a shop other than where I bought the battery.
Any ideas? Fuse maybe?
Old Apr 19, 2006 | 12:53 PM
phipark's Avatar
Not Asian
Do you have anything else connected? Aftermarket alarm or stereo?
Old Apr 20, 2006 | 09:10 AM
bryand178's Avatar
I have an aftermarket audio amplifiers connected and switched on by the stock stereo amplifier turnon lead. I turned off the curcuit breaker that supplies the power to the amps and the alternator is still not charging the battery enough to start the car.
Old Apr 22, 2006 | 10:37 PM
bryand178's Avatar
Well, lately my battery has been charging just fine. After I took my alternator to the shop to get it tested, I guess I must have tighted up a weak electrical connection or something when I reinstalled it.
I measured the battery at over 13 volts with the car sitting overnight, then I started the car and measured the battery voltage at over 14.5 volts. So I guess and hope that the charging system is ok now.
Any body else ever run into this?
Old May 12, 2006 | 06:45 PM
mikamoo's Avatar
I JUST got my CL out of the shop after it dying day after day after day last week. I replaced the battery and it still died overnight. I then replaced the alternator. (ok, paid to have it replaced). Car still died overnight. Took out new battery and got it charged @ Checkers. They said the battery was "good." Car ran fine and then the next morning, same thing. Turns out that I had a "drain" on my battery from an electrical short - specifically, the trunk light. Now that the trunk light short is fixed, I haven't had any problems maintaining a full charged and running vehicle. I would recommend running a diagnostic and search for shorts.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Fandango12
1/2G MDX (2001-2013)
Sep 20, 2015 05:25 PM
brandnewcolony
Sep 12, 2015 10:39 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
