07 TL Problem
Old Jul 17, 2007 | 09:55 AM
o0lancerev0o's Avatar
9th Gear
07 TL Problem
I just got my new 07 TL but whenever i exit out from my driveway in reverse the bottom front end scrapes?? The scraping is also present when i drive up a slight slope has anyone else experienced these problems??
Old Jul 17, 2007 | 10:09 AM
micwiltay's Avatar
All the time. That plastic shield that hangs down on my car is very scuffed. It's just the nature of a car with a low ride and long front end. I find it easy to avoid if you go up or down a slope at an angle.
Old Jul 17, 2007 | 10:16 AM
9th Gear
man that sucks whats the point in having the shield if its just going to scrape every single time i pull outta my driveway
Old Jul 17, 2007 | 10:21 AM
deffjeff06's Avatar
That shield is there to protect engine or suspension parts that could be damaged if they were to come into contact with the driveway, it is there to give you an audible warning.
Old Jul 17, 2007 | 10:25 AM
timmahh's Avatar
it's me, Alan Rickman.
Try exiting at a slight angle - instead of both rear wheels then both front wheels at the same time let the rear ones clear first then turn your wheel to whichever direction you have the most space w/o hitting an object and let the front wheels go down before one another, that may give you enough clearance..
Old Jul 17, 2007 | 10:26 AM
timmahh's Avatar
oh and I think the shield also helps prevent excess water and debris from entering the engine compartment while driving
Old Jul 17, 2007 | 10:33 AM
Ron A's Avatar
Administrator
Welcome to the forum.
Everyone has probably scraped theirs at one time or another.
The shield actually deflects air up to the engine, because the TL is a bottom breather.
It is necessary for cooling the engine, so for anyone out there who may have damaged theirs or are thinking about removing it so it doesn't scrape, think again.
Old Jul 17, 2007 | 10:42 AM
timmahh's Avatar
completely unrelated item but... Ron.. I had never thought of that - maybe that's why I had issues with my 240SX and engine heat =p (it was broken so I just took the entire shield off)
Old Jul 17, 2007 | 11:27 AM
9th Gear
thanks everyone i think im just gonna put concrete on my driveway so its more leveled, but acura should have considered the scraping =/ flaw on their part. I scraped it twice today once exiting and once from going to the bank
Old Jul 17, 2007 | 11:42 AM
OKNBPTL's Avatar
Boomer Sooner!
Maybe you should have considered the slope of your driveway before buying such a low-slung car
Don't even think about buying some exotic (like an NSX) or even a car with a large front air dam i.e. M3 until you get that driveway fixed (or move)
Old Jul 17, 2007 | 11:45 AM
timmahh's Avatar
how very inconsiderate of Acura not to think of your specific drive way when designing the TL =p
Old Jul 17, 2007 | 11:58 AM
9th Gear
its not only my driveway its any sloped area lol
Old Jul 17, 2007 | 12:08 PM
pnoi521's Avatar
Registered TL Owner
I know right? They forgot to consider my friends driveway too! the hell is wrong with Acura?!
Haha j/k but seriously, just go at an angle. It isn't that big of a deal. The only time mine gets scraped is when I go too far into a parking spot and when I go down a steep driveway without an angle.
Old Jul 17, 2007 | 12:53 PM
Will Y.'s Avatar
Registered but harmless
Try backing in when parking in the driveway.
Scraping would be an issue for me if I drove forward and up into my driveway, but I always back in (straight driveway rather than circular-- can't afford a mansion with that type of driveway just yet... ), so my TL's deflector never scrapes.
Old Jul 17, 2007 | 05:18 PM
riomp300's Avatar
I have a steep drive way and if I drive too fast to the drive way or leaving from it, I scrap the bottom so I learned to take it easy. The TL is low but not as low as some super cars like these " Supercars stop Paris" At least our cars wont grind a whole city into gridlock when we exit a carpark
Old Jul 18, 2007 | 12:19 AM
9th Gear
How about speed bumps do you guys have problem with those??
Old Jul 18, 2007 | 12:31 AM
Will Y.'s Avatar
Not my stock TL, at least no problems with speed bumps in SoCal roads, garages, etc.
Old Jul 18, 2007 | 12:49 AM
gauravp123's Avatar
RBP > WDP, NBP, SSM etc
haven't scraped any speed bumps and the only steep hill that gives me a problem is exiting my sister's driveway in her house in NJ...I can't do any sort of angle on the way out, the driveway is super narrow with huge rock walls on both sides...SUPER narrow, so I have to sustain minimal scrapage
Old Jul 18, 2007 | 12:57 AM
9th Gear
kinda embarassing if i must say haha
Old Jul 18, 2007 | 11:06 PM
LaCostaRacer's Avatar
I found just the opposite. I can easily go forward on my driveway with no scraping, but backing in causes lots of scraping for me unless I go at an angle.
Old Jul 19, 2007 | 04:10 AM
Jim in Oregon's Avatar
That plastic piece is there to help direct air into the radiator. I have scraped mine lots of times. I just take my Dremel tool and grind down the scraped part until it looks like new again. I figure it'll stop scraping after a while if I keep grinding down the plastic...he he.
Old Jul 19, 2007 | 05:01 AM
007TL-S's Avatar
Be kind to us truckers !
just remove it, and be done with it!...if something is hit , it's just due to negligence & awareness of one's action's!
Old Jul 19, 2007 | 09:55 AM
XS2K's Avatar
If you scrape on your own driveway, move. If you scrape going to the bank, don't go, or find a different bank. My other car is a "59 Austin Healey; now that is low, really low. You learn to go over almost anything at an angle; works almost every time.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
