06 TL tranny issues (surprise)
Old 03-23-2020 | 11:41 AM
  #41
horseshoez's Avatar
Latent car nut
Originally Posted by whitetiger5
oops. My bad. I thought he got the AV6, getting the same thing just doesn’t compute.
Agreed, hence my comment above about him buying an inferior transmission.
Old 03-24-2020 | 07:46 AM
  #42
Edwin Mathew Flores's Avatar
not same transmission, turns out it’s an 06 oddessey
3.5 trans. Only roadblock installing was range sensor was different had to move harness over for compatibility. Other than that bolted on perfectly.
Midnight Mystery (04-02-2020)
Old 03-24-2020 | 08:18 AM
  #43
horseshoez's Avatar
Latent car nut
Unless your new transmission is a BAYA, then it is inferior. It cannot be any simpler than that.
The following 2 users liked this post by horseshoez:
Midnight Mystery (04-02-2020), TheSauceBoss (03-25-2020)
Old 03-24-2020 | 08:44 AM
  #44
aight bro.
Old 03-26-2020 | 02:39 PM
  #45
Any one know the overall capacity of ATF the trans needs? Some places I’ve read 7 quarts others 8.
thanks
Old 03-28-2020 | 10:23 PM
  #46
thanks
yer
Old 03-28-2020 | 11:15 PM
  #47
whitetiger5's Avatar
thanks
It all depends on what you are doing. the trans capacity (from bone dry) is 7.6 qts? may very slightly (+/- .1 qts ) based on year I believe OR 3.1 qts when changing. If you are swapping a trans that came from another car, then there is definitely some fluid in there, and you best bet is to start off with somewhere between 3.1 and 6, run it a bit drain, refill with 3.1, drive it, drain and refill with 3.1 once more.
The first time you drain it will put you right at the mark where you need to replace only 3.1 any consecutive time and the other two changes are your 3x3 to get rid of all the old fluid in there that may be old, contaminated or just non-honda brand.
Old 04-01-2020 | 12:14 PM
  #48
perfect! Thanks this is exactly the info I was looking for.
Old 04-01-2020 | 04:19 PM
  #49
Stephen Maxwell's Avatar
Hello , , 2006 TL base , trany randomly ( once a week) will slip into N at stop light , then it re-engages , , is this a common failure or is it a simple shift solenoid.
other than that it shifts strong and has no noise i replaced fluid twice w/ OEM Honda fluid when purchased 2 mnths ago PLEASE HELP!!
thanks in Advance
Old 04-02-2020 | 01:22 PM
  #50
thanks in Advance
Possibly the neutral switch/ range sensor
Old 04-05-2020 | 08:59 AM
  #51
is it possible its the filter ???
Old 04-05-2020 | 09:19 AM
  #52
horseshoez's Avatar
Latent car nut
Highly unlikely.
Old 04-05-2020 | 10:10 AM
  #53
thank you sir that helps
Old 04-06-2020 | 04:48 AM
  #54
Edwin Mathew Flores
Well Mr. Flores you get the Gold star of the day / week , Even after i high jack your thread , Your suggestion was the fix , not a band aid but the fix , I drove it all day after changing the range sensor it shifted better than ever thanks bro .
Will it last ?? , I cant believe i put a DURALAST Part on my car, but im broke w/ all bullshit going on (covid shutdown) so.......we shall see ill keep everybody updated THANK YOU EVERYONE , Thanks again Edwin!
The new Norm : "Stay the fuck away from me "
Edwin Mathew Flores (04-08-2020)
Uready
05-21-2018 03:52 PM
dylankerns
10-25-2016 05:40 PM
mcottrell95
01-22-2014 04:52 PM
Bxscig
01-11-2012 07:51 PM
mmcv6
02-11-2011 12:11 AM
Quick Reply: 06 TL tranny issues (surprise)
