Gas pedal vibrates
Old May 20, 2018 | 12:29 PM
Uready's Avatar
7th Gear
Gas pedal vibrates
I have a 06 tl base with 210k km's.
Tranny replace and overhaul this past January
Trans fluid is brand new, still pink.
When I'm between 1000 and 2000 rpm, the gas pedal vibrates. It only does it under a load. It goes away over around 3k rpm
My friend thinks it's the torque converter. The tranny rebuild still has warranty with the shop.
Any input will help
Old May 20, 2018 | 01:29 PM
Uready's Avatar
7th Gear
I'm not sure if the pressure switches were done.
Old May 21, 2018 | 02:19 PM
Uready's Avatar
7th Gear
Bump. Vibrates in all gears. I put it in trip tonic mode to confirm.
It's not a big vibrate, but it's a slight vibrate.
Will worn out 3 and 4 gear switches cause this. I'm not throwing a code
Old May 21, 2018 | 02:24 PM
Take it to the shop to take a look then!
Old May 21, 2018 | 02:30 PM
Jackass's Avatar
No.
More than likely bad/collapsed mounts.
Old May 21, 2018 | 02:35 PM
Uready's Avatar
7th Gear
The shop is two hours away. Im going to get it diagnosed local first. Then go to them if it's tranny related. Every gear shifts very smooth and no jerks ever.
Old May 21, 2018 | 02:57 PM
Uready's Avatar
7th Gear
Originally Posted by Jackass
No.
Would bad mounts cause it to only vibrate under a load.
I'm trying to rule out any internal issue.
Old May 21, 2018 | 03:52 PM
Uready's Avatar
7th Gear
I'm a tech but still fairly new
If it was the torque converter, the shudder would only happen around 50mph and it would allow the whole car to shake pretty much. Almost like you're driving over hundreds of small bumps.
Torque converter shudder would only last for a few seconds then go back to normal. My vibration doesn't go away unless I let off or get it past 2k rpm
And the trans would slip
Maximus2006
May 4, 2011 12:16 AM
coo1est
Sep 27, 2008 11:31 AM
Motohip
Jan 24, 2005 03:53 PM
dennis
Jan 3, 2003 03:18 PM
