05 tl 30k maint.?
Brake fluid is a 3-year service item. I would wait till next year to do it on an 05 unless you think you have a mushy pedal or you know you've faded the brakes before (possibly boiled the fluid)...
6MT info: I would change the trans fluid at this point. OEM Honda MTF is a dyno oil and shears down after about 20-30k miles. If your transmission shifts fine and you don't have the notchy 3rd gear problem, I recommend you just get new Acura/Honda MTF. If you do have the notchy 3rd gear problem, go with GM's Synchromesh "Friction Modified" fluid. This should get rid of that. This is also a dyno fluid so change at the same interval as Honda MTF...
5AT info: I would change the trans fluid at this point. Just get new Honda ATF...
Also get a new engine air-filter, and cabin pollen-filter...
Originally Posted by THTL
Is it really necessary to replace the transmission fluid at 30k miles.
What is the different between the old and new Honda ATF. thanks.
IS changing the transmission fluid the same as flushing it.
It is, however, common practice on automatics to do a drain & fill 3 times in a row while driving several miles between each drain to get as much old fluid out as you can. The reason being that when you drain an auto trans, less than half of the old fluid comes out (due to all the mechanics retaining fluid).
At the 30k service honda and acura recommends, replacement of the oil, trans fluid, cooland, brake fluid, engine air filter, rotate and balance of the tires. The 30k service is also pretty costly!
*Brake fluid should be changed ever 3 years and has nothing to do with vehicle mileage.
If your local H or A service department recommends anything besides what's clearly laid out in the owners manual, they are just trying to rip you off...
so let say i called up an Acura dealer and ask for the transmission fluid change. Do they do the drain and fill 3 times? Anyone know or recommend a good Acura dealer in Sol Cal.
thanks.
thanks.
Originally Posted by 94eg!
*The factory fill type-2 Coolant lasts 90k miles before it needs to be replaced.
THANKS ALOT GUYS!!! i actually work at a honda dealership well was. . . . i used to sell cars which was funny hahhaaha anyway umm i stole an acura tl 05 clean very clean it was a trade in for a pilot and we gave him 23.200 and i got it for that price greatr deal huh anyway my tech said for me to change all my fluids brake, tranny, and oil and 2 cabin filters and he said he would do it for 100 bucks is that a good deal??????????
Hines57
Sep 24, 2015 01:58 PM
what kind of maintnece required fo 30 k thats best anyone know? THANKS
