04 problems
Old May 6, 2005 | 10:10 PM
1st timer's Avatar
UB6IB9
04 problems
what kind of problems does the 04 TL have? A friend of mine just bought one and i want to just give him a heads up,what should he look out for?
Old May 6, 2005 | 10:34 PM
rets's Avatar
Moderator Alumnus
04? I guess the original owner or dealer "should" already update all teh necessary or safety TSBs into that car. Plus, that car "should" have TU2 EL42s tires.
Old May 6, 2005 | 11:11 PM
RSA_Secure's Avatar
FIGHTING ILLINI
-The earlier ones had trasmission related TSB.
-Lossy memory seat setting is another one.
Old May 7, 2005 | 01:07 AM
1st timer's Avatar
UB6IB9
what is TSB ?
Old May 7, 2005 | 01:09 AM
youngTL's Avatar
Registered Abuser of VTEC
Originally Posted by 1st timer
what is TSB ?
Technical Service Bulletin. All dealers should be aware of them.
Old May 7, 2005 | 05:20 AM
1st timer's Avatar
UB6IB9
What is wrong with the tranny? And when you say earlier ones,how early?
Old May 7, 2005 | 06:41 AM
neuronbob's Avatar
You may want to check the 3G Garage, a stickied post at the top of the page. It lists all known issues with the 2004 TL. The primary issues are as listed above. Some people have had more issues than others. I'm one of those who's had only minor issues.
Old May 7, 2005 | 07:29 AM
Wildcat Jon's Avatar
Don't buy one. Wait for an 05. VIBRATION!
Old May 7, 2005 | 10:27 AM
DMZ's Avatar
DMZ
Head a da Family
And tell your friend to buckle up his seatbelt and get ready for potential symphony of rattles!
Old Sep 19, 2017 | 10:54 AM
rcg851's Avatar
1ST TIMER
I think when they are talking about transmissions they are talking Generation 2 from 99 to 03 which I believe almost have 100% failure at some point. Although there was a recall early on I think that has run its course.
Old Sep 19, 2017 | 11:06 AM
TheSauceBoss's Avatar
Originally Posted by rcg851
1ST TIMER
The general consensus on this forum is that 04-06 automatic transmissions are weak/delicate. It also doesn't help that fraction of all owners actually change their tranny fluid regularly, have changed their pressure switches, trans filter, etc.
It's really hit or miss. Personally, I wouldn't risk it unless the mileage was under 100k. Getting a tranny rebuilt on a high mileage 04 will likely cost just as much as the car is worth in the first place.
Old Oct 2, 2018 | 12:16 PM
Hollow24's Avatar
Question do a 04 acura tl a transmission from Japan have the same mount locations from the stock transmission that came with the car
Old Oct 2, 2018 | 12:21 PM
horseshoez's Avatar
Latent car nut
I do not believe there is any such a thing as a 2004 TL from Japan. You're better off with a 2006-2007 transmission from a North American Accord V6 (often referred to as an AV6 transmission), the tag on those transmissions is BAYA.
Black Tire
Dec 18, 2017 08:15 AM
L1ability
4G TL Problems & Fixes
Nov 1, 2016 09:08 AM
User 12221
Oct 18, 2016 05:23 PM
User 12221
Oct 14, 2016 12:21 AM
