[DIY] Add some security - Shock Sensors to Factory Alarm
#201
takin care of Business in
Received 4,732 Likes
#202
FYI to all: I mounted the tilt sensor inside the driver's side kick panel (at the aft end of the kick panel near where the front end of the sill meets the aft end of the kick panel). You'll figure it out once you have the sill and kick panel off. There's a nice little nook for it to fit in. Sorry, don't have pics.
#203
rockstar143 (11-05-2013)
#205
I know this is an old thread, but I bought a DEI 504K shock sensor w/ valet switch and it has five wires to hook up? See below... My questions is will the shock sensor turn off when driving if we connect to a constant 12V source? And do I need to connect that ignition wire? If so where is that wire located?
Red - 12v input - Add a fuse like the DIY.
Black - Ground input - Right above the fuse box.
Yellow - Turn on input (ignition) - Where do I connect this wire to?
Green - first stage output (light impact, short pulse output) - Not needed, using blue wire.
Blue - second stage output (hard impact, 1 sec pulse output) - Hook this up to the hood trigger.
Thanks!
Thanks!
#206
Installing the dual stage shock sensor, DEI.
Anyone - get the 1st stage warning to work?
1st stage is the warning
2nd stage sets off the alarm.
Did anyone wire this up correctly? Where does the blue wire of the shock sensor wire up in the TL? Anyone use Relays?
#207
If you have a small chirp or siren, all you would have to do is wire the green wire to the siren for the warning.
The blue wire hooks up the hood sensor.
#208
Registered Bike Offender
Lots of great info here. First, thank you for the awesome DIY!!! I'm going to be doing this soon and have a few, more technical questions that I didn't see addressed. If I missed them, I apologize in advance and accept the ridicule.
Since you hooked the shock sensor up to constant 12V and GND, does it not mean that it's active all the time? If there is an impact while driving, doesn't the dash come on telling you that your hood is open?
Also another question for nfnsquared: I assume the purpose of using the diodes is to isolate the sensor outputs. Don't they just switch the output to GND when triggered? Why would one sensor tripping cause a problem on another sensor if they aren't isolated? Do the outputs stay at logic high or are they floating?
Final question: I found an awesome datasheet for the tilt sensor 507M here explaining the pinouts: http://www.installer.com/pdf/507m.pdf
I could not find a similar document for the 504D or the 504M (or any 504 for that matter). I even emailed tech support for such a document and am still waiting for a response. Does anyone know where I can get a datasheet for this part?
Thanks!!
Edit: Found one for the 504C http://carmedia1.com/pdf/504C.pdf
Could someone confirm the pinouts/wire colors/functions?
Thanks!!
#209
Just wanted to bump this up since its still a relevant thread and I also wanted to get some feedback from users that are still using it and how it's still working. I was thinking of getting the 504D but with the photos not being available anymore it seems like a tough install.
#210
Sorry I have all the pics downloaded just need to reupload them.
The install is super simple. Mine works great, it's less sensitive than it was before but I assume that's because the ziptie I used got loose and my car vibrates like crazy due to my exhaust.
Coming back from groceries, I sometimes forget to unlock my car before closing my trunk and the shock from closing the trunk while the alarm is armed makes the alarm sound.
#211
Adding Shock Sensors to the Factory Alarm
I've explored the topic of adding a shock sensor a few times when I bought the car but never found a good DIY on what to do.
So what's a shock sensor?
It's a sensor that detects a shock or impact.
When the shock or impact is detected, it sets off the factory alarm.
Our car doesn't have a warning siren so it doesn't "beep beep" when someone lightly hits your car.
It will just set off the alarm no matter how hard the impact.
You can change the sensitivity of the shock sensor.
Demo Video:
How does it work?
Well, as you know our TL comes with a factory alarm that goes off if the doors or trunk or hood is opened without the keyfob or keyhole.
When the sensor is wired, it means everything is in harmony, no disturbances.
When it detects a shock or impact, it sends a signal to the hood latch switch wire which tricks the alarm system thinking that the hood was popped open, therefore setting off the alarm.
Most of you are wondering, when you're in a mall or something and sets off your alarm but obviously you're oblivious to it as our oem keyfob doesn't alert us anything.
That's right, but if someone hits your car, they'll probably less likely "hit and run" because your car alarm is going off, and that will alert people nearby. That means that person who hit your car will think "damnit I'm caught and everybody is watching me".
If someone bangs your car by accident (with grocery bags or elbow), it'll set off the alarm and just really tell them to be more careful next time when they park next to a sexy car.
The beauty of this DIY is that you don't have to install a shock sensor, but you can install a glass sensor, proximity sensor, or tilt sensor to the factory alarm.
Or, you could install ALL 4 of those!
Now you know why to add shock sensors, lets get to it!
NOTE: I apologize in advance that the picture quality sucks!
The pictures I took were good, but they ended up being like 250kb each so I optimized them using a site and they turned out to be like 20KB each.
This means fast page loading, for the small price of quality! =)
Materials List:
1. Shock Sensor (DEI 504D).
Purchased from eBay for like $12.
2. 4 Butt connectors (18-22AWG)
3. 1 Splice Connector or T-Tap connector (18-22AWG)
4. Spool of 18 AWG wire.
5. Mini Add-A-Fuse (with 3A fuse)
6. 1 Ring Terminal
Steps:
There are 3 wires we have to wire up.
It's that easy to install a shock sensor.
Therefore I will divide this DIY into 3 sections for each wire.
Wire 1: Trigger Wire (Blue Wire)
Wire 2: Positive Wire (Red Wire)
Wire 3: Ground Wire (Black Wire)
1. Open up your DEI 504D bag, and you'll have a sensor and a harness.
2. Connect the end of the harness with the green wire looped into the blue wire's pin.
3. Go out to your car, and place the shock sensor and its harness in the driver seat.
4. Cut off the one end of the sensor harness.
Before:
After:
We'll be wiring the blue wire first, which is the trigger wire.
This wire will go to the hood latch switch wire.
As always, UNPLUG YOUR NEGATIVE BATTERY TERMINAL BEFORE WIRING!
1. Grab your spool of wire, and feed the wire through the firewall (while your spool unravels itself).
You can do what I did which is poke a hole through the rubber seal with a bunch of wires (I already did this for my accord fog install).
You'll have to remove the lower dash panel at this point. (NOT the dash with the VSA, Mirror, etc. The one under it)
There's just one screw at the right and you just pull the lower dash panel down, starting from the back.
(Sorry for blurry picture, it looks like there's 4 wires but there's only 2)
OR you can use the hole in the firewall outlined in this DIY:
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diy-aftermarket-amp-install-speaker-install-audiocontrol-matrix-install-w-pics-580314/
2. Extend this wire (while your spool is unravelling itself from inside the cabin) all the way to the hood latch.
At this point, you could do what I did which was remove the front bumper to access the hood latch switch wires easier. I believe you can do this without removing the front bumper by jacking up your car and doing it from beneath.
Here's a GREAT video to show you how to remove the front bumper:
3. Pop the latch cover (just a few clips) and you'll see the hood latch switch connector.
4. Unplug that connector.
It has the green/black strip wire we need to tap into
5. As you can see, there's not much space to tap into. All you have to do is remove the electric tape around it and crack open the loom.
Much better:
6. Route your green wire into the latch cover and place it beside the latch switch connector, ready to tap.
Notice how I DIDN'T route the green wire around the cover, but through it?
7. Using your splice connector, tap the green wire into the green/black stripe wire.
8. Plug the connector back in.
We're done with the outside of the car.
Tidy up the wires, and run it along the side.
9. Back inside the cabin, you want to cut the spool of wire, now that you have your desired length from the cabin to the hood switch.
10. Strip the insulator on the wire from the hood latch switch and the blue wire from the sensor harness.
11. Take a butt connector and connect these two wires together.
The trigger wire is now wired and done with.
Stage 2: Wiring the Positive wire
1. Strip back the insulator on the red wire on the sensor harness.
2. Take your spool of wire and cut a wire about 1-2 feet.
Strip the insulator at both ends.
This extra wire is just for "slack".
3. Connect one end of this "slack" wire to the red wire on the sensor harness using a butt connector.
4. Now take your add-a-fuse, and add a 3A fuse to the slot B for the accessory.
5. Take the other end of the "slack" wire and connect it to the add-a-fuse wire using the butt connector already on the add-a-fuse.
6. Route the add-a-fuse through the top of the fuse box cover.
7. Remove the 20A fuse from the middle row second from the left. It's like the recline fuse which is constant 24/7.
Stick this 20A fuse into the add-a-fuse.
8. Now plug the add-a-fuse into the fuse you took the 20A fuse out of (middle row, second from the left).
(The second add-a-fuse is for my footwell LEDs)
All done wiring the positive wire!
Now onto the last wire: ground wire!
STAGE 3: Ground wire
1. Strip back the insulation on the black wire of the sensor harness
2. Know how we made a slack wire of about 1-2 feet for the positive wire?
Well, do the same with the negative wire and strip the insulator back on both ends!
3. Connect one end of the slack wire to the black wire using a butt connector.
4. Connect a ring terminal to the other end of the "slack wire".
5. Take this ring connector and bolt it to a ground bolt.
I used the ground bolt right under the steering wheel (I used the same for my accord fogs).
The bolt is a 10mm.
All done wiring the shock sensor!!!
At this point, go ahead and plug in the negative terminal on the battery.
Test it out!
Here's how:
Sit in your car.
Lock the doors using the remote and lock again to hear the beep.
Wait about 30 seconds.
Tap your foot on the ground (assuming the shock sensor is just sitting on the ground as I have not told you how to mount yet!!).
The red LED inside the sensor should light up telling you it detected a shock, and the alarm will go off.
Press unlock on your remote to stop the alarm.
If you have gotten this far, everything is pretty much done.
You just have to mount the sensor somewhere...
STAGE 4: Mounting
To be honest, this stage is pretty much up to you.
DEI recommends installers to zip tie the sensor to a large bunch of wires in a central location.
Many installers say no to the zip tying it to wires, but instead to something solid and metal.
I mounted the sensor using zip ties to the metal support beam thing right above the gas pedal and to the right of the steering column.
On the side of the sensor is the sensitivity adjustment so make sure that's accessible.
Put everything back together and you're done.
Alternate Trigger Wire Wiring
Source: anthracitecl
Thanks to our member anthracitecl, there is an alternate source for the trigger other than the hood latch.
This would mean there is no need to remove the bumper - and you save some extra wire too lol
Here are his instructions:
Hood latch switch wire(Green/black) comes out from relay control module(bottom of fuse box).The relay control module is part of underhood fuse&relay box. When you look at wire loom coming out from under the fuse box, there's Green/Black wire(There's only 1 Green/Blck wire and it changes to Yellow/Red to hood latch.). To reach that Green/black wire bottom of the fuse box,you have to unbolt 2 10mm bolts that hold fuse box. You might have to remove intake, but i didn't. I wired it up to that Green/black wire.
Here are some pics.
My little screw driver pointing out Green/black wire.
This pic is after i soldered wire(i used blue wire for extend) to green/black wire.
Credits:
s2000gtx, mb190, anthracitecl
Cheers.
Demo Video:
How does it work?
Materials List:
6. 1 Ring Terminal
Steps:
Before:
After:
Much better:
The bolt is a 10mm.
Test it out!
Here's how:
Sit in your car.
STAGE 4: Mounting
Here are some pics.
Credits:
Cheers.
DUCRDX (06-29-2019)
#212
Fixed the photobucket images and have them uploaded on acurazine.
If a mod can edit the first post with the contents of the post above that'd be greatly appreciated!
(Use "Source" of post above and copy to "Source" of original post)
After confirming that it show up right, please delete these two posts (ONLY after confirming it shows right!)
Thanks!
GP16
Thanks!
GP16
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
09-17-2015 09:01 PM
