[DIY] Add some security - Shock Sensors to Factory Alarm
Old Apr 28, 2012 | 11:51 PM
guitarplayer16's Avatar
Adding Shock Sensors to the Factory Alarm
I've explored the topic of adding a shock sensor a few times when I bought the car but never found a good DIY on what to do.
So what's a shock sensor?
It's a sensor that detects a shock or impact.
When the shock or impact is detected, it sets off the factory alarm.
Our car doesn't have a warning siren so it doesn't "beep beep" when someone lightly hits your car.
It will just set off the alarm no matter how hard the impact.
You can change the sensitivity of the shock sensor.
Demo Video:
http://www.youtube.com/watch?v=rJo0KRugCzg
How does it work?
Well, as you know our TL comes with a factory alarm that goes off if the doors or trunk or hood is opened without the keyfob or keyhole.
When the sensor is wired, it means everything is in harmony, no disturbances.
When it detects a shock or impact, it sends a signal to the hood latch switch wire which tricks the alarm system thinking that the hood was popped open, therefore setting off the alarm.
Most of you are wondering, when you're in a mall or something and sets off your alarm but obviously you're oblivious to it as our oem keyfob doesn't alert us anything.
That's right, but if someone hits your car, they'll probably less likely "hit and run" because your car alarm is going off, and that will alert people nearby. That means that person who hit your car will think "damnit I'm caught and everybody is watching me".
If someone bangs your car by accident (with grocery bags or elbow), it'll set off the alarm and just really tell them to be more careful next time when they park next to a sexy car.
The beauty of this DIY is that you don't have to install a shock sensor, but you can install a glass sensor, proximity sensor, or tilt sensor to the factory alarm.
Or, you could install ALL 4 of those!
Now you know why to add shock sensors, lets get to it!
NOTE: I apologize in advance that the picture quality sucks!
The pictures I took were good, but they ended up being like 250kb each so I optimized them using a site and they turned out to be like 20KB each.
This means fast page loading, for the small price of quality! =)
Materials List:
1. Shock Sensor (DEI 504D).
Purchased from eBay for like $12.
2. 4 Butt connectors (18-22AWG)
3. 1 Splice Connector or T-Tap connector (18-22AWG)
4. Spool of 18 AWG wire.
5. Mini Add-A-Fuse (with 3A fuse)
6. 1 Ring Terminal
Steps:
There are 3 wires we have to wire up.
It's that easy to install a shock sensor.
Therefore I will divide this DIY into 3 sections for each wire.
Wire 1: Trigger Wire (Blue Wire)
Wire 2: Positive Wire (Red Wire)
Wire 3: Ground Wire (Black Wire)
1. Open up your DEI 504D bag, and you'll have a sensor and a harness.
2. Connect the end of the harness with the green wire looped into the blue wire's pin.
3. Go out to your car, and place the shock sensor and its harness in the driver seat.
4. Cut off the one end of the sensor harness.
Before:
After:
We'll be wiring the blue wire first, which is the trigger wire.
This wire will go to the hood latch switch wire.
As always, UNPLUG YOUR NEGATIVE BATTERY TERMINAL BEFORE WIRING!
1. Grab your spool of wire, and feed the wire through the firewall (while your spool unravels itself).
You can do what I did which is poke a hole through the rubber seal with a bunch of wires (I already did this for my accord fog install).
You'll have to remove the lower dash panel at this point. (NOT the dash with the VSA, Mirror, etc. The one under it)
There's just one screw at the right and you just pull the lower dash panel down, starting from the back.
(Sorry for blurry picture, it looks like there's 4 wires but there's only 2)
OR you can use the hole in the firewall outlined in this DIY:
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diy-aftermarket-amp-install-speaker-install-audiocontrol-matrix-install-w-pics-580314/
2. Extend this wire (while your spool is unravelling itself from inside the cabin) all the way to the hood latch.
At this point, you could do what I did which was remove the front bumper to access the hood latch switch wires easier. I believe you can do this without removing the front bumper by jacking up your car and doing it from beneath.
Here's a GREAT video to show you how to remove the front bumper:
3. Pop the latch cover (just a few clips) and you'll see the hood latch switch connector.
4. Unplug that connector.
It has the green/black strip wire we need to tap into
5. As you can see, there's not much space to tap into. All you have to do is remove the electric tape around it and crack open the loom.
Much better:
6. Route your green wire into the latch cover and place it beside the latch switch connector, ready to tap.
Notice how I DIDN'T route the green wire around the cover, but through it?
7. Using your splice connector, tap the green wire into the green/black stripe wire.
8. Plug the connector back in.
We're done with the outside of the car.
Tidy up the wires, and run it along the side.
9. Back inside the cabin, you want to cut the spool of wire, now that you have your desired length from the cabin to the hood switch.
10. Strip the insulator on the wire from the hood latch switch and the blue wire from the sensor harness.
11. Take a butt connector and connect these two wires together.
The trigger wire is now wired and done with.
Stage 2: Wiring the Positive wire
1. Strip back the insulator on the red wire on the sensor harness.
2. Take your spool of wire and cut a wire about 1-2 feet.
Strip the insulator at both ends.
This extra wire is just for "slack".
3. Connect one end of this "slack" wire to the red wire on the sensor harness using a butt connector.
4. Now take your add-a-fuse, and add a 3A fuse to the slot B for the accessory.
5. Take the other end of the "slack" wire and connect it to the add-a-fuse wire using the butt connector already on the add-a-fuse.
6. Route the add-a-fuse through the top of the fuse box cover.
7. Remove the 20A fuse from the middle row second from the left. It's like the recline fuse which is constant 24/7.
Stick this 20A fuse into the add-a-fuse.
8. Now plug the add-a-fuse into the fuse you took the 20A fuse out of (middle row, second from the left).
(The second add-a-fuse is for my footwell LEDs)
All done wiring the positive wire!
Now onto the last wire: ground wire!
STAGE 3: Ground wire
1. Strip back the insulation on the black wire of the sensor harness
2. Know how we made a slack wire of about 1-2 feet for the positive wire?
Well, do the same with the negative wire and strip the insulator back on both ends!
3. Connect one end of the slack wire to the black wire using a butt connector.
4. Connect a ring terminal to the other end of the "slack wire".
5. Take this ring connector and bolt it to a ground bolt.
I used the ground bolt right under the steering wheel (I used the same for my accord fogs).
The bolt is a 10mm.
All done wiring the shock sensor!!!
At this point, go ahead and plug in the negative terminal on the battery.
Test it out!
Here's how:
Sit in your car.
Lock the doors using the remote and lock again to hear the beep.
Wait about 30 seconds.
Tap your foot on the ground (assuming the shock sensor is just sitting on the ground as I have not told you how to mount yet!!).
The red LED inside the sensor should light up telling you it detected a shock, and the alarm will go off.
Press unlock on your remote to stop the alarm.
If you have gotten this far, everything is pretty much done.
You just have to mount the sensor somewhere...
STAGE 4: Mounting
To be honest, this stage is pretty much up to you.
DEI recommends installers to zip tie the sensor to a large bunch of wires in a central location.
Many installers say no to the zip tying it to wires, but instead to something solid and metal.
I mounted the sensor using zip ties to the metal support beam thing right above the gas pedal and to the right of the steering column.
On the side of the sensor is the sensitivity adjustment so make sure that's accessible.
Put everything back together and you're done.
Alternate Trigger Wire Wiring
Source: anthracitecl
Thanks to our member anthracitecl, there is an alternate source for the trigger other than the hood latch.
This would mean there is no need to remove the bumper - and you save some extra wire too lol
Here are his instructions:
Hood latch switch wire(Green/black) comes out from relay control module(bottom of fuse box).The relay control module is part of underhood fuse&relay box. When you look at wire loom coming out from under the fuse box, there's Green/Black wire(There's only 1 Green/Blck wire and it changes to Yellow/Red to hood latch.). To reach that Green/black wire bottom of the fuse box,you have to unbolt 2 10mm bolts that hold fuse box. You might have to remove intake, but i didn't. I wired it up to that Green/black wire.
Here are some pics.
My little screw driver pointing out Green/black wire.
This pic is after i soldered wire(i used blue wire for extend) to green/black wire.
Credits:
s2000gtx, mb190, anthracitecl
Cheers.
Old Apr 28, 2012 | 11:52 PM
An example of the shock sensor (DEI 504D, same as mine) added to the factory alarm in action on a Corvette.
Old Apr 29, 2012 | 12:02 AM
chardness's Avatar
your DIYs are amazing! cheap, worthwhile, and easy to follow.
Old Apr 29, 2012 | 12:16 AM
VanyDotK's Avatar
excellent write up, awesome!
Old Apr 29, 2012 | 12:25 AM
ez12a's Avatar
the overexplainer
nice job man
Old Apr 29, 2012 | 12:30 AM
06tl4life's Avatar
very nice man! By any chance do you have the link for the ebay shock sensor you got?
Old Apr 29, 2012 | 12:38 AM
Undying Dreams's Avatar
3G garage!!
Old Apr 29, 2012 | 02:04 AM
A SiQ TL's Avatar
good idea, and very nice diy write up.
Is this shock sensor adjustable?
Old Apr 29, 2012 | 02:12 AM
24no7's Avatar
UA6 SSM TL
Sweet DYI!!!
if you ever decide to come to vegas, let me know. I will be waiting for you at the airport with my LEDs bulbs, and this sensor LOL
Old Apr 29, 2012 | 02:35 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Real nice.
Wanna do mine?
Old Apr 29, 2012 | 08:17 AM
J35A8's Avatar
07 WDP TL-$
Sweet and easy.
Old Apr 29, 2012 | 08:43 AM
Jesstzn's Avatar
I had one on one of my systems .. was great .... except any body going by on a hot Harley set it off. Fortunatly the system was setable so the alarm only went of for 30 seconds.
How do you deal with this with the factory alarm? We have a few around town that go off for hours till the police authorize the tow company to disarm it.
Not nice to have your alarm going off for hours at a time.
Old Apr 29, 2012 | 09:07 AM
I bought mine from here
http://www.ebay.ca/itm/DEI-504D-STIN...ht_1790wt_1163
Yup, there is an adjustment knob on the side of the sensor.
Originally Posted by 24no7
Sweet DYI!!!
Haha man this wiring job is really simple
Originally Posted by TheChamp531
Real nice.
Wanna do mine?
Some day lol
Well, the factory alarm only goes off for 2 minutes.
You can always set the sensitivity, too.
Old Apr 29, 2012 | 09:26 AM
I'm also adding a rocker switch so that I can disable the shock sensor if I want.
I'll be updating the DIY with that too, once I find a rocker switch I like.
Old Apr 29, 2012 | 09:58 AM
clsdave's Avatar
2005TL(6MT)
Thanks for your time and effort on this DIY! It's a fairly simple and cheap upgrade.
I planned on doing this a couple a years ago. I purchased the parts but just never got to it. They're still in my basement. Not much of a hurry since the car is either in the garage or viewable from my office window. We usually take my wife's civic if we need to leave it unattended. That's were I should install it!
Old Apr 29, 2012 | 10:55 AM
Waveform's Avatar
'06 NBP TL 5AT NAV
Great DIY, thank you!
I like the kill switch idea because my wife and kids pass by the TL when it's home in the garage and the alarm might go off every time they go in or out of the house. My teenager tends to slam the entrance door just for fun.
Old Apr 29, 2012 | 12:31 PM
s2000gtx's Avatar
Excellent write up. Superb!!!!
Old Apr 29, 2012 | 12:34 PM
Bladehopper82's Avatar
University of Tennessee
You did it again guitarplayer16! Yet another way to spend some money on the ride. At least this one is inexpensive and it's also very practical. If we can't catch someone for bumping into our cars, at least we can scare them a bit...lol.
Old Apr 29, 2012 | 01:57 PM
A SiQ TL's Avatar
Yeah, the corvette in the video you posted had this. I thought it was a nice addition if you're ever anywhere where it might be set off frequently by traffic, etc.
Old Apr 29, 2012 | 02:20 PM
Steven Bell's Avatar
Dude, you rock! Outstanding job, buddy.
Old Apr 29, 2012 | 04:47 PM
mb190's Avatar
To add to this excellent thread. Removing the bumper would make the install much easier, but I didn't remove the bumper for my install. If you look at guitarplayer16's pics, there are plenty of room for you to get at the connector from underneath.
I installed a glass/sound sensor as well as the shock sensor. The microphone for the glass/sound sensor is directional, so placement location is important. I hid the microphone behind the center air vent, out of sight...but still very functional. Tapping the glass with key will trigger the alarm.
Attached Thumbnails [DIY] Add some security - Shock Sensors to Factory Alarm-cimg1569.jpg   [DIY] Add some security - Shock Sensors to Factory Alarm-cimg1570.jpg   [DIY] Add some security - Shock Sensors to Factory Alarm-cimg1567.jpg   [DIY] Add some security - Shock Sensors to Factory Alarm-cimg1629a.jpg   [DIY] Add some security - Shock Sensors to Factory Alarm-cimg1635.jpg
Old Apr 29, 2012 | 05:18 PM
UA6~RBP's Avatar
-Brandon
Spectacular DIY!
Old Apr 29, 2012 | 05:35 PM
anthracitecl's Avatar
Nice DIY!!! Great write up! I added this shock sensor into my TL right after i bought it. I love it! Actually i transfered it from my CL to TL.
Only difference is that i didn't wired mine to hood latch. I wired it to hood latch wire from underhood fuse box.
Old Apr 29, 2012 | 07:08 PM
omnuts's Avatar
2006 TL: WDP/Ebony
Great write up man, excellent work as usual
Old Apr 29, 2012 | 07:27 PM
Hey, I try when I can =)
It is indeed very cheap!
No problem!
I hope you'll find it useful!
Wiring in the rocker switch should be a very easy task.
I just need to find a cheap but good rocker switch lol
Special thanks to you =)
Exactly!
It might not alert us if someone bumps our car, but it'll sure scare the hell out of them and give them a message lol
If you want, you can buy the whole kit (DEI shock sensor + switch + LED) that's from the video with the corvette.
http://www.sonicelectronix.com/item_...cted-504K.html
It's a little more expensive.
I was about to buy it but then I figured I would just buy 2 shock sensors and wire my own rocker switch for the same price.
Yes, you can clearly see that there is room to work with from underneath the hood latch cover =)
Special thanks buddy.
I need to figure out how to place my sensor better as it doesn't detect any impacts with my hand.
That's actually a great idea!
Instead of removing the bumper or working from underneath the bumper, you can just use an add-a-fuse for the hood latch wire fuse.
PMed you for more info to add to this thread
Old Apr 30, 2012 | 07:50 AM
**WhItE-aNgEl**'s Avatar
Ive been looking for something like this. I just ordered my shock sensor. Is the sensitivity adjustable? Cuz I don't want it going off all the time since I park in the street since my car is too low to go up my drive way :p
Old Apr 30, 2012 | 08:12 AM
SharksBreath's Avatar
BANNED
^it is adjustable.
GP...awesome write up man. i'm going to add this (for once) very cheap mod to my list.
thanks again. bookmarked.
Old Apr 30, 2012 | 03:41 PM
Cheers guys!
Funny today I was leaving for work and put my guitar in the trunk (doors still locked and alarm still active) and when I closed my trunk the alarm went off lol
I suppose I'll have to remember to unlock my doors before closing the trunk.
Old Apr 30, 2012 | 06:39 PM
Want to see the shock sensor in action?
I'l smack my fender tommorow morning in an empty mall lot to show you guys.
Old May 1, 2012 | 12:39 AM
A SiQ TL's Avatar
Any more on this ^^^
Old May 1, 2012 | 12:43 AM
Yup! The DIY is being updated tommorow along with a demo video.
Cheers.
Old May 1, 2012 | 01:01 AM
A SiQ TL's Avatar
that's what I'm talkin about
Old May 1, 2012 | 10:30 AM
swoosh's Avatar
takin care of Business in
SEXY DIY GP !!!
I have already ordered the shock sensor, will be installing it in the next few days !!!
we need this in 3G Garage !!!
Old May 1, 2012 | 03:16 PM
Well, here's the video portion.
Old May 1, 2012 | 04:38 PM
Thanks to Steven, the thread has been updated with the demo video and the alternate trigger wiring method.
Old May 1, 2012 | 05:10 PM
swoosh's Avatar
^^^ WTF is the frame....almost made me dizzy....
it can be used for raping women
Old May 1, 2012 | 05:13 PM
I don't know lol it's my first time uploading to YouTube.
YouTube asked me if they can fix my shaky video and I clicked yes, so I think that's what happened.
EDIT: Just went on YouTUbe and removed the "stabilize" feature from the video.
Old May 1, 2012 | 05:18 PM
swoosh's Avatar
but thanks for doing the DIY bro....really really need this....like i really really needed all the other mods LOL
Old May 1, 2012 | 05:36 PM
lilsid112's Avatar
This is awesome! Thank you for another great DIY!
Old May 1, 2012 | 05:45 PM
Great job! Thanks for sharing!!!
By the way, I have 2 new extra DEI shock sensors laying around in my room. If anyone plan for buying one,hit me up.
