What kind of oil do you use for RLX Hybrid during changes?
Old 03-12-2017, 12:05 PM
jmt4m's Avatar
Hi all. I usually just take my car to the dealer for my oil changes, since it's not too expensive. I've yet to take my 2016 RLX Hybird in yet.....my question is (and I can't seem to find the right answer) do you use synthetic oil or the regular oil for the changing at the dealership
My dealership seems to have 2 different types of oil changes: Conventional and Synthetic.
Please advise....thank you in advance!
Old 03-12-2017, 12:22 PM
Torch & Pitchfork Posse
TampaRLX-SH's Avatar
Received 1,806 Likes on 793 Posts
It is a matter of personal preference. If you follow the MID maintenance schedule, there is no reason this engine will not last 200K+ miles. Neither is a bad choice. Per the manual:
The following 2 users liked this post by TampaRLX-SH:
jmt4m (03-12-2017), pgeorg (03-12-2017)
Old 03-12-2017, 01:51 PM
VT Skier's Avatar
On the same subject, does anyone know where (or whether) the RLX has floor jack points in the front and rear? The owner's manual doesn't mention any (that I could find), and I'd like to jack up the front to change the oil, using the side points (mentioned in the manual) for jack stands while doing so.
The rear (when I get to the differential) has the tow hook, but I'm not sure that's meant for supporting weight pressing straight up into it.
Any info would be greatly appreciated.
And as to the OP's question -- I plan to use Mobil 1, which is around $25 for five quarts at Wal-Mart, and the standard Acura oil filter.
I'm also considering installing a Fumoto drain lever, but I haven't decided on that yet.
Thanks in advance.
Jon
Old 03-12-2017, 02:13 PM
Old 03-12-2017, 02:42 PM
pgeorg's Avatar
Adding to what Tampa posted:
pcloadletter (04-01-2017)
Old 03-13-2017, 08:08 AM
VT Skier's Avatar
Thanks for the help everyone. Looks like the rear tow hook and something (?) in the front. I'll see if I can find the front spot that matches the diagram.
Old 03-13-2017, 08:59 AM
Grandpa
George Knighton's Avatar
Received 2,609 Likes on 1,475 Posts
It'll be obvious when you see it. :-)
It's very much like the jack point we've had on the front of Honda chassis...pretty much forever.
Old 03-13-2017, 09:02 AM
Grandpa
Originally Posted by jmt4m
... do you use synthetic oil or the regular oil for the changing at the dealership
I use synthetic as supplied by the dealer; however, I know that this is excessive and unnecessary.
Under absolutely no circumstances should you let someone put an additive in the oil and charge you for it.
Older service techs who are not very high up the food chain mightn't be too aware of the damage that can be done.
(Like having to replace the VCM rocker arm assemblies on newer J Motors. Just don't add crap to oil changes.)
pgeorg (03-13-2017)
