Fan noise
Old Dec 14, 2015 | 02:05 PM
miner's Avatar
Fan noise
Has any RLXers notice an abnormal amount of fan noise when ventilation system is being used? I have begun to hear somewhat loud ticking when fan is on. I took out the cabin fitler and did not see anything lodged in the fan blades.
Old Dec 14, 2015 | 07:36 PM
George Knighton's Avatar
Grandpa
Not here. I never really hear the fan unless I hit the max defrost button.
Old Dec 15, 2015 | 05:11 AM
neuronbob's Avatar
Same here.
Old Dec 15, 2015 | 11:14 AM
hondamore's Avatar
No fan noise here either.
My first thought was a leaf stem stuck in the fan, but since you've ruled that out, I suspect a trip to the dealership may be in order. The only other thing I can think of that would cause a ticking would be....well....have you upset any mob bosses recently??? If so, when the ticking stops would be your biggest worry.
Old Dec 15, 2015 | 03:19 PM
holografique's Avatar
The only ticking I hear is the "timing belt chirp" that is addressed by this TSB:
TSB 14-025 - Timing Belt Chirps, Applies To: 2014 RLX – ALL, 2015 RLX - ALL
When idle (at a stop light) and entertainment system is off, you can hear it penetrate through the cabin.
Old Dec 16, 2015 | 06:00 AM
ddswv's Avatar
Miner:
Not that this may apply but I have a 2015 Acura TLX SH-AWD Advance that started having a ticking noise when we left for a trip. It continued for about 35 minutes until I turned the audio system on. This has happened a few times since and I have found turning the audio system on and off it stops. I'm assuming the noise cancelling speakers are emitting the sound even though it sounds exactly like a fan ticking. Let me know if this helps you.
Old Mar 27, 2016 | 03:36 PM
Vickiemalone's Avatar
Fan noise
Yes, my RLX has an annoying whining, noise. I've had a 96 TL 3.2. 2004 RL and driven the 2015 TLX, none of them have this annoying fan noise. I've had it in the dealership several times, they said it's a trait of the vehicle, they all have it. I'm not so sure that's correct.
randomwalk101
Jul 24, 2018 08:50 AM
RxWorld
Jun 5, 2016 08:11 AM
polish_pat
Dec 14, 2015 02:18 AM
tbonesteak
Dec 3, 2015 07:22 PM
caseman22
4G TL Problems & Fixes
Nov 23, 2015 08:33 PM
