2014 RLX side skirt popped out
Old 10-29-2015, 11:00 AM
4th Gear
jafo69's Avatar
Hi
my 2014 RLX side plastic side skirt popped out.
Never been hitted , no outside impact. (no damage, dent even scrach).
brought Acura stevens creek dealer, Santa Clara CA, and they said this one isn't covered by warranty.
Is it true?
I attached pics
Attached Thumbnails 2014 RLX side skirt popped out-img_0478.jpg   2014 RLX side skirt popped out-img_0479.jpg   2014 RLX side skirt popped out-img_0481.jpg
Old 10-29-2015, 11:04 AM
Received 16,260 Likes on 11,971 Posts
lift the panel and put it back onto the knob. its very easy
jafo69 (10-29-2015)
Old 10-29-2015, 11:14 AM
IIDXholic's Avatar
Pretty much a big F--- Y-- from the dealership, especially for their flagship. But yes a simple fix it is as jusn explains.
jafo69 (10-29-2015)
Old 10-29-2015, 11:20 AM
4th Gear
jafo69's Avatar
So Is it right it can't be covered by warranty?
Old 10-29-2015, 11:23 AM
why do you want it to be covered under warranty?
Pop it back into place. its one of those U-shaped locks and clips... so you can see the knob exposed, you'll need to LIFT the panel up to align the knob and the hole
Old 10-29-2015, 11:38 AM
mtiaz's Avatar
this happened on my TL-S due to a curb
sadly they don't pop back into place, you have remove the side skirt and attach it from the top end and then the bottom end
The following 2 users liked this post by mtiaz:
justnspace (10-29-2015), neuronbob (10-29-2015)
Old 10-29-2015, 11:41 AM
^i'm assuming because of the U-lock hole thingy
Old 10-29-2015, 11:52 AM
neuronbob's Avatar
Received 4,612 Likes on 2,193 Posts
Doesn't sound too difficult. So how much did the dealer say this process would cost you?
Old 10-29-2015, 12:18 PM
4th Gear
jafo69's Avatar
Dealer said can't be covered warranty and bring the car to body shop. dealer can't do body related.
Old 10-29-2015, 12:24 PM
4th Gear
jafo69's Avatar
You are right!! U shape lock open to front. just drop by body shop and they said remove side skirt panel and re-assemble.
cost $30. ANYWAY problem solved, but disapointed Acura service. 15minutes work to un-screw, remove and re-assemble. Dealer said can't do that. but easier than oil change.
One of a kind
Texas
06-15-2016 01:29 PM
ReplayMan
12-21-2015 09:27 AM
RDX8002
1G RDX Problems & Fixes
10-29-2015 09:07 PM
RDX8002
1G RDX (2007-2012)
10-29-2015 09:05 PM
TheBlackDiamond
1G CL DIY & FAQ
10-29-2015 09:53 AM
Quick Reply: 2014 RLX side skirt popped out
