2014 RLX side skirt popped out
3 Attachment(s)
Hi
my 2014 RLX side plastic side skirt popped out. Never been hitted , no outside impact. (no damage, dent even scrach). brought Acura stevens creek dealer, Santa Clara CA, and they said this one isn't covered by warranty. Is it true? I attached pics |
lift the panel and put it back onto the knob. its very easy
Pretty much a big F--- Y-- from the dealership, especially for their flagship. But yes a simple fix it is as jusn explains.
Originally Posted by IIDXholic
(Post 15596247)
So Is it right it can't be covered by warranty? |
why do you want it to be covered under warranty?
Pop it back into place. its one of those U-shaped locks and clips... so you can see the knob exposed, you'll need to LIFT the panel up to align the knob and the hole |
this happened on my TL-S due to a curb :tomato:
sadly they don't pop back into place, you have remove the side skirt and attach it from the top end and then the bottom end |
^i'm assuming because of the U-lock hole thingy
Doesn't sound too difficult. So how much did the dealer say this process would cost you?
(Post 15596301)
Originally Posted by mtiaz
(Post 15596280)
sadly they don't pop back into place, you have remove the side skirt and attach it from the top end and then the bottom end cost $30. ANYWAY problem solved, but disapointed Acura service. 15minutes work to un-screw, remove and re-assemble. Dealer said can't do that. but easier than oil change. |
