Loss of Network Comms Blue Screen Error
Old Apr 28, 2020 | 04:23 PM
kboo74656's Avatar
Trying to collect some data to see how many are getting this error. If you have experienced this error reply to the thread YES and if not reply NO. Also add the model year of your RDX after the answer please. Nothing else is needed.
Old Apr 28, 2020 | 04:57 PM
SilverRDX2017's Avatar
No 2020
Old Apr 28, 2020 | 05:14 PM
JB in AZ's Avatar
no 2019
Old Apr 28, 2020 | 09:39 PM
russianDude's Avatar
I had this happen on 2020 number of times, maybe once a week on average, took it to dealer, they said no codes, they supposedly re-tighten all wires. Has not happened again, but I have not been driving much for over a month, so don’t know if it’s fully fixed.
Old Apr 29, 2020 | 01:19 AM
Madd Dog's Avatar
2019. No.
Old Apr 29, 2020 | 09:08 AM
Ender519's Avatar
2020. No.
Old Apr 30, 2020 | 11:34 PM
sonyfever's Avatar
I thought there was a TSB about this? Something about the MOST connector.
No such issue on my car, 2019.
Old May 1, 2020 | 06:15 AM
no, no TSB, 2020
Old May 1, 2020 | 06:11 PM
Dereileak's Avatar
I have not had this error, but I think most of the problems and errors people are having are connection related (harness connectors).
I had some weird things happen, like weird sounds coming from my driver mid speaker. I was installing the spare tire and while I had the back apart I checked the connections on the amp in the rear. And wouldn’t you know it one of the main harnesses was loose, Wasn’t seated all the way or clipped in to lock, who knows what else they control through that harness.
I am sure there are other harnesses on people’s cars that are loose or not connected well, and that can cause all sorts of issues. I never had a weird thing really happen in my car, electronically since then I can say, my infotainment center has been flawless even (knock on wood).
Literally all it takes is one little mishap on the assembly line connection a harness and someone can end up with a lemon car that could be dangerous, and may exhibit all types of constant problems
the problem I have with all this is that the dealership always says to people, oh there were no codes! Well Acura get your shit together and write some damn codes when bad stuff happens, it’s part of your job to track failures so you can bloody fix them! Being a software developer, that is pretty sad to see that you are not able to capture the data you need to fix the issues that people are having. They should easily be able to plug in a tool at the dealership that says, hey bad signal between these modules, recorded at this time, how hard is it 😂 I mean most of this stuff exists already, they are doing something wrong
honestly when a failure happens they should be sending themselves log data through the cellular they already have active in the car, they could fix it without even seeing the car, and they could collect every failure of every car, how much better could it get! what freaking year is it Acura? 1995? 😂 send me an application, I’ll fix it for you!
maybe you already do this, but it sure doesn’t seem like it
Old May 1, 2020 | 07:03 PM
agree, they should store the damn code. When dealers see this blue screen as a picture on your phone they are not surprised, they told me they saw it before. Their standard procedure is to check all connections. But its a best guess, they have no idea.
Old Jun 19, 2020 | 05:09 AM
EE4Life's Avatar
Forum Contributor
See TSB 20-031 - Popping/Crackling from the Speakers; Display Blank in the 2019 and 2020 TSB threads.
Old Jun 19, 2020 | 08:50 AM
The blue screen with communication lost and system will restart, according to my dealer there were no shutdown codes stored as specified in TSB. I wonder if its a different issue?
Old Jun 19, 2020 | 09:42 AM
kboo74656's Avatar
Mine never stores any code when it happened. I’m at the dealer now and I bought the TSB with me to show them. I should have an answer in about 30 min.
Old Jun 19, 2020 | 11:36 AM
kboo74656's Avatar
Well I have to wait. The parts for the new connectors will be here tomorrow but they don’t have the tools to make the new connections. They will be here in about a week. Service tech told me the tools are similar to what they use for coaxial cable.
Old Jun 19, 2020 | 01:56 PM
so they will do TSB even though there is no code for blue screen?
Old Jun 19, 2020 | 02:11 PM
kboo74656's Avatar
My dealer will. Ever time I get the blue screen I take a screenshot as proof. Plus I have all the other symptoms also. Your service dept should to if your having this issue and you’ve brought your car in for it previously or you have documented it. I have never seen a code stored for this error on my system. When you read the TSB it lists several symptoms caused by the bad connections.
Old Jun 19, 2020 | 02:26 PM
yea, when I was at a dealer it was before TSB, so they said they checked connections and could not find anything. I had a picture too. I do not have popping sound in a stereo, and have not gotten blue screen for a while,l
Old Jun 19, 2020 | 02:37 PM
kboo74656's Avatar
Mine did the same thing when I first had the blue screen but I kept on documenting it when it happened and kept making appointments for it. So now I have a lengthy documented trail of complaints at the dealer and online directly to Acura’s CS Line so they can’t BS me. Also my service manager is awesome and does what it takes to keep me happy as a customer. I’ve had this error or some variation of it show it’s head around 8 or 9 times in the last 12 months or so.
Old Jun 19, 2020 | 02:40 PM
well, it cant hurt to get this TSB done, thought I did not particularly like that they have to remove a lot of parts. But I just wonder if this TSB will solve connection lost blue screen issue. Have you had other symptoms like popping sound in speakers?
Old Jun 19, 2020 | 03:01 PM
kboo74656's Avatar
Yep but mine sounds like a loud squelch you would hear on handheld radios being held close together and the mic keyed at the same time. Then the audio stops and the screen goes blue for a short while, the system resets, and continues off exactly where it left off like nothing happened. Hopefully the new connectors are more secure than the current ones.
Old Jun 19, 2020 | 04:41 PM
my issue is different. I never had any sound issues, or screen going blue for short time. I would get occasional blue screen “communication lost, system will now restart”. Picture attached in this thread. It would do complete reboot, and be back to normal. I dont know if this TSB will fix it?
did you get same error as a first picture in this thread?
Old Jun 19, 2020 | 04:52 PM
kboo74656's Avatar
Yes that pic is from my car. You described it exactly the way mine would act. That’s what this TSB addresses.
Old Jun 19, 2020 | 05:10 PM
cool, I will get it next time at dealer. Other times there was no TSB, so they had no idea how to fix it.
Old Jun 27, 2020 | 05:32 PM
How does the fix holding up? No more blue screen? I used to get it, but not anymore, so I am contemplating if I should complain about it
Old Jun 27, 2020 | 05:56 PM
kboo74656's Avatar
Still waiting on the tools to come in that are required to do the fix. Hopefully they come in this week so I can drop off my car. Also I’m waiting on other parts from 2 other TSB’s(Brakes pads, rotors, and new lower control arms).
Old Jun 28, 2020 | 06:52 AM
do you know if for brakes TSB they try to reproduce the noise before they agree to do it? Cause sometimes its not there....
Old Jun 28, 2020 | 06:58 AM
kboo74656's Avatar
They didn’t have to hear it for me since I’ve reported it so many times. Also I have a great service manager who cares.
Old Jun 29, 2020 | 03:19 PM
JDMaccord3.5's Avatar
Yes, 2019
I think this only happened once, system rebooted itself afterwards
Old Jun 29, 2020 | 03:50 PM
Originally Posted by JDMaccord3.5
Yes, 2019
did system register shutdown code? You can check it yourself in system diagnostics...
Old Jun 29, 2020 | 06:25 PM
I can't recall if there was a code shown during the reboot process, I was focused on not crashing while driving in the rain
This happened earlier this month, maybe a code was registered.
Do you mind giving details how to check the diagnostics or at least enter in that mode?
Old Jun 30, 2020 | 12:39 PM
yes, steps detailed here (read inspection procedure section)
http://www.urvi.net/forumfiles/SB/B20-031.PDF
if code was thrown, it will store it there until someone clears it. So if you have a code, you will see it. Let us know what you find.
Old Jun 30, 2020 | 12:46 PM
got updated brake pads too. Was never a big issue for me, occasional squeaks in cold, but figured why not if it makes it quieter.
I decided to skip blue screen fix for now, has not really had it happen for a while. I can do it any day, dealer is 5min from my house, and they are also super nice. Glad acura is coming back with the fixes, RDX is a great car once you address all the issues
Old Jul 28, 2020 | 08:25 AM
4th Acura's Avatar
Retired Geezer
No 2020
Old Jul 28, 2020 | 08:50 AM
kboo74656's Avatar
Well the TSB that addresses the blue screen doesn’t work. After getting the TSB done the blue error screen with loss of network comms came back along with the high pitched squeal and reboot. The so called fix only lasted about 2 to three weeks them my system would make the high pitched squeal sound everyday, several times a day and finally the reboot happened with everything else.
Old Jul 28, 2020 | 09:09 AM
Did system stored shutdown code? You can check yourself. I had mine done, so far its been good, but too early to tell
Old Jul 28, 2020 | 09:13 AM
kboo74656's Avatar
No code stored. I check every time after the reboot.
Old Jul 28, 2020 | 09:20 AM
check soft errors, its a different menu item, will have time of the event too
Old Jul 29, 2020 | 06:24 AM
I was also thinking since you said it got worse, maybe they did it wrong? It should not get worse. Maybe they messed up nee connector installation
Old Jul 29, 2020 | 06:54 AM
kboo74656's Avatar
I’m going back to the dealer tomorrow to have them check the connections.
Old Jul 29, 2020 | 07:07 AM
markm929's Avatar
I would have to agree with this thought, as the TSB was meant to increase the stability of the connectors. At least that is how I read the TSB write-up.
