Drivers Side Door Was Replaced
Old Aug 17, 2024 | 01:16 PM
Mo3MoE's Avatar
9th Gear
Hello, 24' RDX here, my driver's side door was replaced recently since my key lock had to be replaced also due to attempted break in. However, now when exiting the vehicle my seat does not retract and my radio stays on. Acura mentioned that there may have been a harness or connector not plugged in correctly, therefor my car doesn't know weather im in or out the car. The Body Shop says that everything was plugged in as normal and it should be working that Acura should be able to fix the issue. Acura wants to charge me 3-4 hundred jus to check. Everything worked fine before the door was replaced. Any suggestions would be greatly appreciated!
Old Aug 19, 2024 | 10:36 AM
Optical Toxin's Avatar
Back to the body shop. It worked when you dropped it off, it should work when you got it back.
Old Aug 22, 2024 | 11:43 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
As Optical Toxin said - go back to the shop that replaced the door and get them to "fix" the issue and get your vehicle working as it should be. If not, then work with your insurance company if they recommended this shop - guessing this is/was an insurance claim. Keep us posted.
Old Aug 22, 2024 | 03:25 PM
how is this not the first step? Cmon OP…
spoolin01
2G RDX Problems & Fixes
Aug 21, 2024 02:50 PM
spireview
1G RDX Problems & Fixes
Sep 29, 2018 09:31 PM
cbrig
1G RL (1996-2004)
Jun 9, 2008 02:46 PM
Standout
Jun 1, 2005 07:50 AM
