Drive Mode Unavailable Message
Old Mar 29, 2022 | 02:29 PM
  #121
Midi Man's Avatar
Originally Posted by anoop
I thought I posted about this but I can't find the post. At the last service (02/2022) they did the following:
0101Q0 INFOTAINMENT SYSTEM - REPLACE THE FARKA CONNECTORS S/B: 20-031 S/B: 21-009
Yes they did TSB says most buss but the dealership called it that FARKA.
This RDX is about to blow my piston really a said day for Acura.
To me it can't compete with the Acura 90's cars.
bad city gas millage, Brake pedal is like an old ford.You have to mash it hard t to make it stop.
And the dealerships they remind me of bill's garage. I told them to call Acura hot line yet they insist on doing it again.
I don't know where Acura calls it Precision Crafted Performance. I call it Poorly Crafted Poop.
Old Mar 29, 2022 | 02:36 PM
  #122
anoop's Avatar
I think the Acura strategy is affordable entry-luxury performance. What they got right is the steering and suspension and to some extent the engine, what they got wrong is the transmission and brake feel. Most car makers don't get everything right. BMW, e.g. does poorly in steering and suspension but does well with engine, transmission, and brakes.
Reliability is a different matter and seems to have taken a back seat at Acura. Although, given the minimal changes with the RDX refresh, perhaps they have focused on reliability for that.
Old Mar 29, 2022 | 02:48 PM
  #123
Midi Man's Avatar
From what I know BMW has engine issues also.
They steering and suspension on the RDX is a plus.. But I would not say it's leaps and bounds over the 90's Acura's. They don't advertise Entry Luxury brand., They advertise Precision Crafted Performance.
Reliability I am getting the feeling this RDX will not stand up like the older ones did. I am really sorry I bought this car I should have gotten a Lexus at least they go for quality and reliability.
Honda / Acura has lost it. Really a sad day. Read the other day that they are teaming up with GM for there EV's to add insult to injury. Acura already is showing the issues with there electronics so now go with GM who is notorious for electronics and other issues .. How dumb is dumb.
Mazda made a smart decision to team up with Toyota.
Old Apr 24, 2022 | 05:21 PM
  #124
CHL's Avatar
CHL
3rd Gear
I’ve had the same issue. A quick reboot didn’t fix it but letting the car sit for few hours did.
Old Apr 25, 2022 | 08:31 AM
  #125
Midi Man's Avatar
After you had the most buss connectors fixed like I did?
Mine happened again after they fixed the most buss connectors.
Old Apr 25, 2022 | 08:59 AM
  #126
CHL's Avatar
CHL
3rd Gear
No, I have not fixed any hardware issues. The Acura Service Consultant told me that I should use the original Apple USB drive or the Apple Original cable. But, no matter what type of USB drive or cable I used, it happened occasionally.
Old Apr 25, 2022 | 09:09 AM
  #127
Midi Man's Avatar
My happened with no phone attached. There is a TB for the most buss connector to fix this issue. Mine was fixed and it did it again after that. They did it one more time.
Old Apr 25, 2022 | 10:01 AM
  #128
Midi Man's Avatar
Hrere is the TSB
https://static.nhtsa.gov/odi/tsbs/20...60875-0001.pdf
Old Apr 25, 2022 | 06:13 PM
  #129
Funz51's Avatar
Expanse me
as I went to the site above, I came across this one,
https://www.carcomplaints.com/Acura/...NEL-FUEL-GAUGE
its got them all. I looked and found a couple of things I could look at for issues, like looking at logs, etc.
Old May 26, 2022 | 11:43 AM
  #130
CHL's Avatar
CHL
3rd Gear
Drive Mode Unavilable
I had the most buss connectors fixed yesterday. Hope it really fixed the problem.
Old May 26, 2022 | 12:02 PM
  #131
anoop's Avatar
I haven't had the problem recur since getting that done.
Old May 26, 2022 | 02:52 PM
  #132
Midi Man's Avatar
Glad yours is good. Mine happened again after the first fix about 4 months later.
Old Jun 3, 2022 | 08:48 AM
  #133
subin's Avatar
I am about 3 months after the TSB and have not seen the issue yet. However, I did experience a couple of times where I was not able to use the thumb wheel on steering wheel to change preset radio stations with the navigation on main screen. To fix that, I would put the radio on the main screen and select the station manually. After that, the thumb wheel worked again.
Old Aug 3, 2022 | 11:56 AM
  #134
gtssenior's Avatar
After owning my 2019 RDX Advance for 4 years, I had my first occurence of "Drive Mode Not Available" with switching between day and night mode last week. The next day the problem went away. I do have evidence on an iPhone video taken off the screen. Since I have a routine, scheduled maintenance for next week, I will have them go through the Inspection Procedure section in Service Bulletin 21-009 and have the technician see if there are errors logged in the "Shutdown Reason" screen and go from there. I will probably have them order parts and have the connectors and clips replaced at a followup appointment. The flat rate repair time in the bulletin is only 1.4 hours so it should not be a big imposition. Might as well have it done since the warranty extension for this particular issue will expire for me in a couple of years. Based on a customer letter sent out advising of this issue and announcing a warranty extension for it, I would surmise that this is a common issue eventually for many owners.
Old Aug 3, 2022 | 12:45 PM
  #135
ARNY's Avatar
I had 21-009 done but the "drive mode not available" issue still happened sometime afterwards. It just happened that one time and I don't feel like bringing it in again so I haven't bothered to do anything about it.
Old Aug 3, 2022 | 01:23 PM
  #136
Midi Man's Avatar
I had mine fixed and 6 Months them it came back again 6 months later and they fixed it again. I don''t understand either the dealer lied about the fix or Acura has no clue as to what is going on with this issue.
I have dumped my car since I hate Acura and I will never ever buy another one. They are not even in the same league as there old Legends were.The fit and finish is like an American car. It's Lexus for me from here on out, unless Lexus changes and goes to poop.
Old Apr 19, 2024 | 05:41 PM
  #137
trevenarj's Avatar
3rd Gear
Originally Posted by Smilin_Jim
I just wanted to pass this along in case you see this so you know that you probably are not about to get stranded.
Yesterday when I started off to work, the infotainment display started going Bright/Dim/Bright/Dim like it was flipping between day and night mode. The display behind the steering wheel stayed in day mode and the headlights seemed to be staying on. A message then started popping up on the infotainment display that read "Drive Mode Change Unavailable" or something to that affect. It kept doing this during the 20 minute drive to work and again on my way to the shop. I went into the diagnostic screens and found one with a block diagram of the systems. There was one on the right that was labelled gateway and it was changing from green to red and back again about once every five seconds. In addition, two of the subsystems connected to the gateway, chassis and HVAC, were doing the same. I took it to the shop since I couldn't tell if it was an intermittent failure that could go hard at any moment or just a glitch.
The service rep called over the service supervisor, they looked at it and then he looked at me and said "well, that's a first."
Got the car back at the end of the day, they said it was just a software issue that would be fixed next pushed out update and that they had made "some adjustments to the settings" to fix it for now.
Of course the service ticket reads like it was only me saying there was a problem that they couldn't reproduce... I so love my dealership repair department. not
My car started to do the same this evening. Any suggestions?
Thanks’
Old Apr 20, 2024 | 08:04 AM
  #138
Funz51's Avatar
Expanse me
Thanks’
this is a known issue. It is documented on this site.
The meter needs to be replaced.
The software in it is buggy but it cannot be updated.
This I know from experience.
get a video of the issue and send it to the dealer.
Old Apr 20, 2024 | 09:25 AM
  #139
Midi Man's Avatar
I did i was fixed twice by the dealer. on the second time they said they had to ask Acura if they could fix it again.
Well I dumped the car during the pandemic since I didn't lost much.Glad I did. Acura is not Acura of the 90's they are a bunch of hype. That is my opinion
After hearing and going through this and the dealer say this I will not buy another Honda / Acura product again.
THey lost a good customer by stupidness.
Old Aug 31, 2024 | 02:18 PM
  #140
t55J$via's Avatar
Has anyone gotten a resolution for this issue? I had the TSB completed for the MOST bus FAKRA done with replacement part 39540-TJB-A01 but the issue is still happening. I'm at 84K miles now so I'm getting close to the max 100K mile warranty for this issue.
Old Aug 31, 2024 | 02:29 PM
  #141
kboo74656's Avatar
I did. After I had the TSB performed the problem came back after a year. My solution was to trade the vehicle over 3 years ago and rid myself of it. Best decision ever and my current ride is problem free and has an infotainment system that works properly.
Old Aug 31, 2024 | 03:11 PM
  #142
anoop's Avatar
You don’t want to own any newer car (with infotainment and driving assist) without a warranty on the electronics.
Old Sep 1, 2024 | 08:52 AM
  #143
Midi Man's Avatar
Thanks for the info I knew Acura was BSing on the fix.
I had mine fixed and 3 weeks it came back. After a fight with Acura Dealership they fixed it again.My car was very new and low mileage.
I also sold the car and bought a Lexus. Best decision I made for that POS.
If I was you I would contact the Class action attorneys for the case. Since they might be able to reopen the case. I am sure that it's not you alone that is having the issues.
Old Sep 1, 2024 | 09:27 AM
  #144
Geohutch's Avatar
Ditto but service replaced infotainment system
2019 RDX same problems since purchase. I use Apple play
info wiring harness replaced (2020?) - no fix
infotainment sys replaced - no fix (in 2021?)
infotainment system replaced 8/24 -
Still get occasional inability to connect
Orange highlight that indicates where my cursor is pointing randomly moved around the screen. But it was like a backlight behind each location instead of highlighting the full location to select.
Shameful? Incompetent? Who knows. Apple car play works perfectly for me in all rental cars regardless of how high end or low end the car is. So WTF!
side note - backup camera began showing somewhat psychedelic colors - replaced under warranty.
Old Sep 1, 2024 | 10:46 AM
  #145
Midi Man's Avatar
I got that with my 2019 and Android google maps not all the time but the main issue was that when I would start the car the unable to change drive mode would come on the screen and not go away even if I shut the car off. The next day it would fix it's self. Some time I would also get the black screen. What pissed me off the most about it is that I purchased the car for the google map on the LCD screen and I had to use the phone to navigate. I could have just got a $10 phone holder and saved a lot of money, instead I of the 2019 RDX A Spec and what a POS.
Sad day when a $400 phone will work better than a 40 k car.
Now I have a 2022 CPO RX 350 and not one issues with anything in the car. So its Acura Piss poor design.
I don't know where they got Precession crafted performance from, it should be Piss poor performance.
Old Sep 1, 2024 | 12:49 PM
  #146
anoop's Avatar
That 2022 is old RX and rock solid. New RX has a lot of infotainment issues.
https://www.clublexus.com/forums/rx-...3-present-320/
Old Sep 1, 2024 | 01:26 PM
  #147
Midi Man's Avatar
Yes it is and that is why I purchased it Rock solid V6 port and GDI no turbos and no issues.
Anyway so glad I didn't lose to much it turned out to be a very cheap lease on the RDX 2019.
Also you might want to get a Lemon Lawyer involved. Since they said it was fixed and it is far from the truth.
Old Jun 2, 2025 | 09:22 PM
  #148
DrWoo's Avatar
I had the TSB for this completed 3 years ago, but last week it came back on a very wet, humid day. Was at the dealer for another issue on our 2019 today and mentioned this, and service advisor said they would look at it again. Apparently, when the TSB was done 3 years ago, there were 4 connectors that were replaced. Advisor says the TSB has been updated to 10 connectors, and I had the remainder repaired today. Still under the 8 year/100k warranty, so no charge.
Old Jun 3, 2025 | 07:16 AM
  #149
Midi Man's Avatar
Wow the original TSB was not correct. I am so glad I dumped my RDX and got a RX 350 not one issue so far.
Old Jun 4, 2025 | 08:53 AM
  #150
t55J$via's Avatar
Do you have any details of the new or updated TSB? I’m in the same boat and closely approaching 100K and would like to bring this to my dealer.
Old Jun 4, 2025 | 10:01 AM
  #151
MattB16Teg's Avatar
I used to have this and the radio going crazy around when we first got our 19. Forgot to ever do anything about it and haven't seen it happen in years, it wasn't fixed but maybe since the car is garage kept, maybe it isn't an issue?
spinedoc777
3G RDX (2019+)
55
May 22, 2020 12:58 PM
birdonamission
Sep 4, 2016 06:49 PM
thunder04
Console & Computer Gaming
Mar 21, 2008 06:22 AM
redman042
Sep 13, 2006 11:43 AM
jbs221
Oct 5, 2002 08:16 PM
