prl intercooler or k tuner first?
Gearhead
I am on the software side of the house especially when it comes to turbo cars. Typically it is far and away the best bang for the buck and easiest to do. Last street car I built got almost 100 hp from the tune alone. Then I had to start chasing the expensive and/or time consuming stuff to swap out. All with far less gains than just the tune did for me.
If it were any order I'd go:
Tune
Downpipe (if the one from the Civic will work)
Intercooler
If you do some data logging you might find out how good/bad the stock intercooler is. I haven't gotten around to checking it yet as I don't want to be disappointed. There are always to try and improve the stock intercooler.
You really need to think about what you are trying to do holistically rather than bolting on some parts with no clear end goal in mind.
Tune
Intercooler
Tune
Intercooler
Tune
Intercooler
There is a new downpipe with catalytic converter for our car as advertised on this forum (thanks for your R&D and advertising here) that is really tempting for me, but I already did the K-Tuner and need to go to Stage 2 whenever I get the courage to hook it up to my Windows 10 image on my Mac. I will probably have someone do it, as last time it cost me over $400 to replace an ECU that didn’t need to be replaced...thanks Acura of Tempe.
What I really want are lowering springs...1.5 to 2” would be perfect. If y’all find that, please send me a super-fast message so I get them ASAP.....OK, I am being dramatic....I use that in sermons too...gets those good Lutherans to wake up and listen!
It is my understanding that all RDX’s of Generation 3 have an intercooler below the main grille. The throttle response is more sensitive and there is no more lag for the turbo to kick in. I am amazed at how fast this transmission runs through the gears.....we have 10 of them! Stage 2 install is next. Maybe when it cools off in the Fall.
OK, that makes more sense to me....no, I stayed with the stock intercooler. As I mentioned, there is a company that builds the down pipe with catalytic converter (high flow) which in my understanding will make some positive effects in the turbocharger. I confess that I am not anywhere near the knowledge of turbochargers than I am in other areas of my interest.
Does it void the factory warranty if you install an aftermarket intercooler? I am interested in the PRL Intercooler and watched a few YT videos where it’s installed on the 2018 Honda Civic SI 2.0T. Removing the front bummer clips is a PITA but the Intercooler install is straight forward (remove 4 bolts).
Gearhead
I don't really want to go down the "will it void your warranty" discussion. From a purely engineering perspective there is no downside to putting on a better intercooler. Cooling the intake charge more effectively only has positive benefits. The rub will come if you are running more boost that the intercooler can more safely allow you to do. Not to mention the stock intercooler, if like the Civic, is a piece of crap with plastic end caps.
Acura's assumption would be that the reason you dropped in the better intercooler was because you did other mods that necessitated it. That is where you might have issues. There isn't an automotive engineer that could with a straight face tell that a better intercooler somehow caused some problem with the engine.
I don't know if Acura put any temperature and pressure probes before and after the intercooler to see how effective it was. We could at least have some insight to what difference is making and if we can measure pumping losses across it as well.
That being said, I have nothing against modding. I have a 2005 Pontiac GTO with supercharger, cam, heads, CAI, full exhaust + tune making near 600rwHP. Once I threw a cam + tune in there, I had absolutely no expectation for GM to give two shits about me as a consumer of theirs if the motor went out.
Gearhead
It can be an uphill battle for sure when dealing with warranty issues that the dealer or manufacturer claim are as a result of mods. Went down that road with Audi even though I never modded the car. They claimed that because there was a loss of 12v power to the ECU that I was swapping in an aftermarket ECU. Car was in the dealer 7 times because it threw a CEL quite often and usually it resulted in the car coming to a stop on the side of the road. Think how happy I was when it was -20F and the car coasts to a stop on the freeway in the middle of a snow storm with 3 young kids in the back.
Yet Audi refused to take care of the issue. I called every rep imaginable within Audi. I had bought 8 Audi cars in the 5 years prior to that and spent almost 500k with them yet I was stil being hassled that the issue was my fault. I started lemon law proceedings in the state I lived in. Call the state attorney general and Audi was still resistant to fixing my car or giving me another one as they claimed it was my fault. The state AG said take it to Audi one last time before we drop the hammer on them.
They still couldn't find the issue. They brought my car around from service and as I got in the check engine light came on again. I had never touched the car and no way I could have swapped out the ECU in 30 seconds while the car was still running. Game - set - match. Audi folded like a wet napkin and bought my car back at full price even though it was about 18 months into ownership. The miserable way they handled it up that point meant I never bought another Audi since then. I patronized the other German car companies instead. I was totally innocent and had firm ground to stand on and it was still a royal PITA.
As for mods breaking a car, of course they can. When down properly and appropriate care, the car can have a long and healthy life. Case in point is I am still driving a highly modded VW that making almost double the horsepower at the wheels than what it was originally rated at the crankshaft (without any drivetrain losses) and the torque is more than doubled. Over 170k miles, 18 years old, numerous hours at the track, autocross runs, drag strip and just generally fun driving. It still has the original ultra high performance clutch I put in it. My son is driving it now so I am not sure how long it will last in his car but for me it was flawless. I put it together with great parts and never abused it. Always gave it the maintenance it deserved and changed the oil every 5k miles or less with top grade oil. Sent the oil out for analysis and they figure the motor is still looking good.
Went back, called up the customer and the second I said I talked to the head service tech at the dealership he had his car at, he hung up the phone and refused to pick up again. So, scumbag wanted to pull a fast one and thought we would just replace his engine because Toyota wouldn't. In short, I hate people.
I'm in no rush. Not touching anything on the car until it's out of warranty. Also gives time to see if there are any transmission issues that arise from the power bump. I rummaged thru an Accord forum to see if any of them were running into problems with the AT-10 speed and stumbled across a thread arguing about an oil change causing a 5MPG drop and a bitch-fest about why the oil filter was changed at the time of the oil change when it was only Service A. I quickly realized absolutely no intelligent life lived there so I promptly left.
only thing i saw was them stating they havent dyno the rdx yet to post numbers up
