Instructions for disassembling the center console to modify inputs?
Old Jun 24, 2019 | 08:09 AM
Mustachio's Avatar
I plan to swap the functionality of the two USB ports in the center console because I despise the placement of the media-connected port being next to the cup holders. I may even try USB 3.0 ports if they are supported.
Does anyone have or know of where to find the instructions for disassembling the center console? I don't even know where to begin removing panels.
Old Jun 24, 2019 | 05:02 PM
Dereileak's Avatar
Pay for a subscription to techinfo.honda.com and you will have everything you need
I found a way to access most of the extra stuff the higher subscription Service Information Service offers if you pay for the lower ServiceExpress, let’s just say their site is not very secure lol. I took a wild guess at something and was able to access all the dealer level learnings and specific part lookup by vin
Old Sep 26, 2019 | 11:23 AM
Funz51's Avatar
Expanse me
sooo, how did you access the dealer stuff?
Old Sep 26, 2019 | 03:54 PM
Dereileak's Avatar
Do you have the lower subscription?
Old Sep 26, 2019 | 04:22 PM
BoBoish's Avatar
When I disassembled it, I went to an Acura parts site and looked for the console "blow-up" picture...where it shows all the individual parts and numbers. This gives you an idea of how it's put together and can be taken apart. Here's a good example:
https://www.curryacura.com/parts/ord...U9YXV0b21hdGlj
It's pretty small, but if you poke around other sites you might be able to find a better example. If I remember correctly, once you pop the side panels off you can see/touch the wires. That might be all you need to do. You'll then need an extension cable from the first USB to the second if you're wanting to swap them. Of note, you'll need to remove one of the seats (if only removing a console side panel). If you wind up taking the whole console apart, it'd be much easier if you remove both seats. It's really easy to do...just have to be careful taking them out of the car - I actually scratched a body panel when I was moving the driver's seat :-(
Old Sep 26, 2019 | 07:40 PM
Funz51's Avatar
Expanse me
I had one for a month. Just lapsed. Will join again not a problem. How did you?
Old Sep 26, 2019 | 10:41 PM
Dereileak's Avatar
Pm me
scv76
3G RLX Problems & Fixes
Feb 23, 2014 12:48 PM
rlerman
Dec 30, 2008 12:50 PM
kph3
Oct 23, 2005 09:02 PM
allmotor_2000
Mar 9, 2004 06:55 PM
yanotkaj
Aug 19, 2002 05:10 PM
