Upgrade speakers and subwoofer
Old Apr 17, 2020 | 06:48 AM
Edwinrdx's Avatar
Hi i have a base model 9 speaker system can i only upgrade all the speakers and subwoofer without upgrading the amp (use the oem amp that came with)
Old Jul 9, 2020 | 06:47 AM
dieboy's Avatar
Probably but the base models and the tech package model amp seems pretty weak. I had a tech package loaner, and I was turning it up to about 15 to get the same volume levels my advanced package has at about level 5. I wouldnt expect much out of a speaker swap in terms of volume. Clarity may improve however.
Old Aug 18, 2020 | 05:47 PM
gballs's Avatar
7th Gear
What kind of speakers are you putting in the base model? I have a base as well and am thinking about upgrading across the board, including amp.
Old Aug 20, 2020 | 06:45 PM
WunderWagen's Avatar
Wonder if you can replace the amp in a Tech with the Advance amp for more output? I know the rear ceiling speakers are missing but if the power output is much higher it should still work for the other speakers. Does anyone know if the harness connectors are the same?
Old Aug 31, 2020 | 02:40 PM
garunas's Avatar
Do you need this? Did you ever compared adv/A-spec vs. Tech? If you mostly driving alone it is not worth but if somebody sits behind you, then yes
BaoZZeR
42
Jun 11, 2016 01:49 PM
parkmead
Aug 15, 2011 01:24 PM
fanbanlo
May 7, 2009 05:17 PM
RogerPodacter
Nov 7, 2003 07:45 PM
meeh416
Jul 3, 2002 07:21 AM
