Kicker Key 500.1 and sub install question
Hi everyone, I just got a 2022 A-Spec and I am wanting to move my Kicker Key 500.1 and JL sub over from my previous car. The Kicker Key is nice since it has DSP built in, so a Sound Control LC2i isn’t required.
In my Explorer I purchased a harness to make it plug and play into the factory amp and gave me a direct connection to the amp. Does any companies make that for our cars?
Has anyone else used a Kicker Key amp in the RDX? If so how did you do the wiring since it’s 2 sets of wires? Sub and rear speaker?
Thanks for any help!
I ended up taking just the oem sub outputs to the amp. B/c it crosses over so high you don't need the other speaker inputs. Also I determined that changing the phase of the amp by about 45 deg put it on phase with the OEM sub. I tested by using a iphone app that generates any freq up a sliding scale. If you want details of how I determined the phase DM me. Good luck
snoozabelle
Sep 4, 2010 12:22 PM
fobstylez
May 29, 2009 04:20 PM
kimxhiep1017
Sep 2, 2002 06:43 PM
