Missing screw in my mud guard need help with replacement
I was installing the OEM mud guard and when I was about the screw in the last screw I realize I'm missing a screw.
i contacted the seller for a replacement screw but in case they seller won't send me one does anyone know the part number for the screw? Thank you.
FWIW: If you have access to a pick-N-pull yard, you should be able to easily duplicate the missing screw. If not, ACE Hardware stores have an extensive selection of stainless steel sheet metal screws, and should be able to closely duplicate the original. You may also visit a local Body Shop, and ask if they have a similar screw.
The mud guard installation can be done with wheel removal or jack use; but getting the rears on are somewhat tricky:screwing the brackets in is hard because you can't see where the mount holes are. A very short phillips screwdriver or socket will be needed install the the screws behind the tires as well.
The fronts are easy just turn the wheel as per instructions. The rear I used the flexible extension to twist around the narrow space. The clip that I had put in to install the rear bracket does not stay on, I used electrical tape to keep it in place before I screw it in.
DiaBando
17
Jul 19, 2008 03:43 PM
rockyfeller
May 19, 2008 07:59 PM
