Leaking coolant ?
Old May 15, 2020 | 04:38 PM
Gregory Kozlowski's Avatar
Leaking coolant ?
Hey all,
Looks like this is a coolant leak? Can anyone confirm this tube is for coolant? Color of the leak appears to have greenish/yellow haze and is very sticky even though it is all dry. Attaching some pics.. Thanks
Old May 15, 2020 | 05:43 PM
leomio85's Avatar
That's not a coolant line. I'm assuming it's part of the PCV system. No coolant or liquid is going to run thru there. Are you having an issue with oil dilution? Mine is completely dry.
For the future, our coolant is a dark blue, not green/yellow.
Old May 15, 2020 | 05:53 PM
Yea after thinking about it a bit more after posting I didn't think it was coolant either. Ive always been able to smell a scent of gas in the oil but I don't know how diluted it actually is? Why do you ask about oil dilution, how would the two relate? Thanks!!
Old May 15, 2020 | 07:00 PM
leomio85's Avatar
How's the oil level? If it's part of the PCV system, overfilled oil in the crankcase due to oil dilution could create more of a likelihood for oil to enter the PCV system ... and causing it to seep out at that port. Try removing that hose and seeing if the inside of the hose is coated with oil. If so, there's the issue. Mine is bone dry upon removal. Really just speculating, but makes sense to me ...
Old May 15, 2020 | 07:31 PM
Thanks I’ll check that hose tomorrow. It’s just strange that the fluid that leaked has a greenish tint. Let’s see what’s inside the hose and go from there. I’ll report back
Old May 15, 2020 | 11:34 PM
DJA123's Avatar
2020 RDX, Advance, AWD
A hose that doesn't carry fluid appears to be leaking fluid that looks like coolant, but it's not the color of coolant used in this car? Nothing leaking from the engine, that I know, should be 1985 Prestone green. Nothing makes sense here.
Has anyone done work inside the engine area? Maybe a wet funnel or something similar rested on that hose which dripped down to that cover, simulating a localized leak? If it's me, I clean that area and watch it closely for fresh signs of an actual leak.
Good luck.... again.
Old May 15, 2020 | 11:51 PM
Thanks. I’m gonna check the inside of the tube tomorrow. I know I’ve had my fair share of issues with the vehicle but I actually still love the thing. Will report back tomorrow
Old May 16, 2020 | 09:02 AM
Dereileak's Avatar
When is the last time you had the dealer work on the car?
Old May 16, 2020 | 09:05 AM
They have had it a few times over the past 4 months but not to fix anything ‘under the hood’.
Old May 16, 2020 | 09:12 AM
So...I pulled the rubber tube this morning. I found that there was definitely a small amount of residue on the outside edge of the rubber tubing but the inside was dry. I took a toothpick and gently ran it through the plastic male connector (pointing to with red arrow in attached photo) and there was definitely a small amount of some type of liquid in there. I cleaned the area thoroughly and will take it for a good long drive today.
Old May 16, 2020 | 09:46 AM
DJA123's Avatar
If that is part of the PCV system, I think some oily vapor residue inside the tubing could be normal. But the greenish color is a head scratcher. Whether or not that's an active leak is the next logical test...
Old May 16, 2020 | 09:54 AM
If that is part of the PCV system, I think some oily vapor residue inside the tubing is normal. But the greenish color is a head scratcher. Whether or not that's an active leak is the next logical test...
Totally agree. The only other thing I can think of is that I washed y car about two weeks ago with Chemical Guys Clean Slate before applying Turtle Wax Hybrid Ceramic. The Chemical Guys Clean Slate has a yellowish color. I just don't see how the soap could have gotten directly onto that part and nowhere else..seems too coincidental but a possibility nonetheless. Checked everywhere else and I do not see this game residue anywhere. Will take for a drive and report back. Thanks!
Old May 16, 2020 | 11:27 PM
leomio85's Avatar
Oil mixed with water (condensation) can become murky and even congeal into a pudding like consistency. I've seen it on the underside of oil fill caps. That would be my best guess as to what it is. Best remedy is to go out, get it up to operating temp ... and then rip on it like you stole it.
Old May 17, 2020 | 12:43 AM
Wander's Avatar
I'm guessing something dripped down from above, and that tube is an innocent bystander that happened to be in the wrong place at the wrong time. Makes me wonder why that plastic umbrella is there above it.
Old May 17, 2020 | 08:18 AM
I hope thats the case..I cleaned it up really well and went for a drive last night..no signs of anything yet. Going to warm her up good and drive it hard today for a bit and see what happens.
Old May 17, 2020 | 08:39 AM
DJA123's Avatar
Watch it occasionally over time, but I wouldn't be surprised if you don't see a problem here.
Old May 18, 2020 | 10:29 PM
hans471's Avatar
If you think about things enough your mind can create all sorts of problems.
Dustin James Hamilton
Jan 19, 2020 12:47 PM
2Quik
Sep 3, 2019 08:10 PM
CenturionTL
Jun 1, 2018 11:24 AM
mvidal6
ILX
Jul 3, 2015 11:42 AM
