Help with lights in the back
Old Apr 28, 2022 | 05:38 AM
Alphawolf1's Avatar
5th Gear
This is the lights in the back seat. 2020RDX. Can someone tell me what the red lights mean? Also i can’t turn on these back seat lights individually. But they work if i hit the “on” button up front that turns all the lights on. Thanks
Old Apr 28, 2022 | 10:19 AM
Have you read through the owner's manual?
here's a copy if you don't have it: https://techinfo.honda.com/rjanisis/...BTJB2020OM.PDF
Pg. 220 refers to the interior lights
Old Apr 28, 2022 | 10:21 AM
RDX-Rick's Avatar
First thing is I don't have the red lights on my 2020 Platinum Elite. My lights are white. Perhaps yours are red if you have an Aspec model.
The white/red light is only on when the engine is running. I presume this is to make it easier for the rear seat passenger to locate the light in the dark..
The switch on the rear lights will not work unless the switch on the overhead console is set to the "door" position. As you already noticed, setting the overhead console to the "on" position will turn on all the interior lights including these rear lights.
dennis0
5G TLX Problems & Fixes
May 10, 2019 12:32 AM
9932tl
Jan 30, 2014 05:08 PM
Nrp603
Jun 9, 2011 09:21 AM
planman_RENAMED
Aug 22, 2004 03:05 PM
