odd noise after turning off engine
Today, I turned off the engine and opened driver door probably a little quicker than normal. I hear a sound coming from rear area live an electric motor - similar to sound of outside mirrors folding (but they weren't).
Do the electric dampers adjust after turning off engine? It may be there all the time, but first time I've noticed?
I can't say for sure as I haven't fully tested out this theory. I believe if you have the auto brake engaged, the parking brake will auto engage also when you put the car in park and shut it off.
In the following situations, the parking brake automatically operates.
標hen the vehicle stops more than 10 minutes while ACC with LSF is activated.
標hen the driver痴 seat belt is unfastened while your vehicle is stopped automatically by ACC with LSF.
標hen the engine is turned off, except by Auto Idle Stop system, while ACC with LSF is activated.
標hen the vehicle stops with the automatic brake hold system activated for more than 10 minutes.
標hen the driver痴 seat belt is unfastened while your vehicle is stopped and automatic brake hold is applied.
標hen the engine is turned off, except by Auto Idle Stop system, while automatic brake hold is applied.
標hen there is a problem with the Automatic Brake Hold System while automatic brake hold is applied.
lausy (05-21-2019)
KidK
08-21-2013 09:37 PM
