How do I remove this piece? 2016 MDX advanced
Old Mar 9, 2020 | 09:03 AM
rmoran's Avatar
7th Gear
I’m looking at removing this piece so I can drill it and put in a USB socket. Does anyone know how to remove it? Thanks.
Old Mar 9, 2020 | 11:13 AM
RLX-Sport Hybrid's Avatar
You do know there is a socket in that compartment directly below what you are pointing at right? Are you looking to add a second one? Why not wire directly from the fuse box instead?
Old Mar 10, 2020 | 09:04 AM
rmoran's Avatar
7th Gear
Yes, I know there is an outlet. I want to install 2 USB socket plugins in the module I’ve drawn red around. I can tap into the outlet power for ease and convenience. There is no need to run to the fuse box unless I’m using higher voltage. It will be to charge my electronic devices in road trips.
Old Mar 10, 2020 | 02:59 PM
cougar hunter's Avatar
I don't know for certain, but it looks like you will need to remove the two tan pieces on either side of the highlighted panel.
You can also subscribe to the TechInfo website ($10 for a day), which will give you access to repair manuals.
Old Mar 11, 2020 | 09:22 PM
acuratech481's Avatar
Both of the leather covered tan panels need to removed first, this is correct. Then that black piece just pulls out. It's held in by 4 clips.
Mikeg040
3G RDX DIY & FAQ
Feb 7, 2020 09:23 AM
hpcacura
1/2G MDX (2001-2013)
Jan 17, 2020 11:10 AM
Mr.Skytech
Nov 16, 2012 04:08 PM
