Help: 2017 MDX P011A code
2017 MDX SH-AWD
Brake system, trailer stability, hill start, power steering and more light show up. Did a test and it shows P011A OBD Trouble Code
P011A - Generic
Type: Powertrain - Fuel and Air Metering - ISO/SAE Controlled
Description: Engine Coolant Temperature Sensor 1/2 Correlation
Where is that sensor located?
P011A - Generic
know610 (04-27-2022)
[QUOTE=know610;16812979]Is this the kind I would use to test if battery is weak?
[/QUOTE
go to autozone or any auto parts store. They can test it for free. A good battery store can do a load test which is what you need rigjt now. The amazon tester will not load test.
[/QUOTE
know610 (05-02-2022)
Baloney that tester will load test. I have one similar and it works well.
I have this one.https://www.amazon.com/dp/B07Q6NBXQG...NsaWNrPXRydWU=
Thanks all for the help. I think I got it fix after changing Engine Coolant Temperature Sensor. No more error lights led up.
https://imgur.com/a/TPDdBSc
I have a Milton 1260 that heats up a huge coil to load test. I don't use it anymore ,because the Ancel gives a better test and more information.. Blow $41.00 and try it. You will agree.
