Carplay problem
Old Nov 5, 2021 | 01:52 PM
Lalin's Avatar
Carplay problem
All of a sudden when I connect my iphone 8 running iOS 15.02 with an Apple cable to my 2019 MDX, the Carplay screen is blank. Carplay is working (I can command Siri to txt, call, stream Pandora, etc) but screen is dead. The screen works with all the other Acura functions.
I took the car to the dealer and they connected another iPhone with another cable and got the same results. Unfortunately they dont have a clue what is wrong…
Any clues?
Old Nov 5, 2021 | 03:30 PM
Donn0128's Avatar
When did you update your phone? When did the problem start?
I suspect with 15. Acura software is not up to date yet.
Old Nov 5, 2021 | 06:37 PM
Lalin's Avatar
I cannot pinpoint exactly when but I believe it was before 15.
The Acura dealer’s position is “because we dont have an error code, there is nothing we can do” while they are looking at the blank screen…
Old Nov 5, 2021 | 07:05 PM
EE4Life's Avatar
Forum Contributor
You can try the following:
Reboot the iPhone and then re-connect via the cable to CarPlay.
Unpair/delete the iPhone and then pair it again.
Old Nov 6, 2021 | 02:17 AM
bmoua15's Avatar
I have this issue with android auto once every few months. Usually i have to restart my phone, turn off the ignition and let the car sit for a few mins. If nothing else doesnt work I would disconnect the vehicles battery.
Old Nov 6, 2021 | 07:37 PM
Lalin's Avatar
I have restarted the phone and engine a few times and that works only some times.
Disconnecting the battery sounds a bit extreme at this time as I will loose all the memory settings on infotainment and others.
Thmanx
ILX
142
Sep 6, 2023 05:54 PM
thunder04
Technology
Jul 17, 2013 09:05 AM
M T L T L
Nov 30, 2012 10:36 PM
Whiskers
Technology
Jul 26, 2012 03:42 PM
chilimost
Apr 5, 2010 02:27 PM
