2014 MDX on 22's
Old Dec 18, 2013 | 05:06 PM
Nixonride03's Avatar
2014 MDX on 22's
Not sure if any others are interested but here is what our MDX's look like on 22's...285/35/22 with no rubbing what so ever...I am not sure on the offset of the wheels but I can look into that. Please excuse how dirty the car is...She needs a bath!
Old Dec 18, 2013 | 05:07 PM
Oh and larger brakes...anyone know of companies that make larger rotors? Perhaps slotted and drilled?
Old Dec 18, 2013 | 05:54 PM
RL06tech's Avatar
NO like But beauty is in the eye of the beholder, thus,
Old Dec 18, 2013 | 08:08 PM
CTAP's Avatar
I like a little more sidewall... So I'm looking at 20's. But it looks good...thx for posting...I like seeing pics with wheels. I personally think wheels make a huge difference in the styling...just one reason the Audis look so good...they do a great job with wheel/tire size/style and filling the wheel well.
Old Dec 18, 2013 | 09:03 PM
beach109's Avatar
Interesting look, and very large. I'm assuming the ride and handling has changed considerably as well, in a stiffer sense. Which tires were used?
No go on different brakes, unless you want to completely redesign and come up with a custom braking system. It is already as large as they go, and there is no point in a drilled rotor system in the MDX.
Old Dec 18, 2013 | 11:01 PM
krazienluv10's Avatar
nice pics! ya can we get more info on the rim specs? offset/rim width/bolt pattern.... thanks!
Old Dec 19, 2013 | 01:31 AM
Edward'TLS's Avatar
6G TLX-S
That MDX is screaming for a drop.
The big wheels and the thin tire sidewalls make the wheel gaps look even uglier.
Old Dec 19, 2013 | 06:59 AM
I laughed when the OP was like, "No rubbing at ALL!"
looks like there's a lift kit on there! lol
Old Dec 19, 2013 | 02:44 PM
Yeah it does need a lowering kit bad which is why in one of my other posts I asked if anyone knew of a lowering kit of 1-2" for the MDX. I knew there was gonna be some major wheel gap. It seems like the German auto makers like BMW, Audi, and MB understand that when designing a car. They make the wheels sit and tuck perfect.
Tires are Toyo Proxes 285/35/22...I personally would love to have 285/40 or 45/22's but they wont fit...this combo is almost the exact same size as factory. The bolt pattern is 5 X 114.3 and I believe the offset was +35. The wheels are Dub Rio 6 22 X 9.5.
As far as handling and ride it is a bit of a stiffer ride but not nearly as bad as I was expecting. It is still smoother and quieter than MY07 Escalade. You can feel the added weight in the wheels when driving and turning but not too dramatic. The stopping power of the MDX is a bit weak with the stock set up IMHO and I have yet to really test it with the added weight of the new wheels.
What I meant by no rub has nothing to do with the height of the wheels and the gap. The new wheels are considerably wider and put the edge of the tire right in line with the widest parts of the fenders instead of tucked in like the stock wheels. When turning at full lock going both forwards and reverse there is no rub. It is Very, Very close to hitting the inner fender wells but about 1/16th to spare.
I like the look of the rims but hate the fender gap. I am going to have them mount up a set of 20's and see if that looks better. I am also going to be on the hunt for a lowering kit because either way the MDX needs a little drop IMHO.
To each their own and I agree the look isn't for everyone, but I wanted to post up some pics so that other who might be considering a change have at least something to go off of. I am part of a few different vehicle forums and the people on this site, or should i say this MDX portion, really seem to be more geared toward stock equipment and factory accessories. Not that this is a bad thing, just thought I would throw a little aftermarket into the mix.
Old Dec 19, 2013 | 08:53 PM
CTAP's Avatar
Agreed...pretty conservative as a whole. Keep us posted on the progress...whether you go with 20s or lower...appreciate it.
Old Dec 19, 2013 | 11:36 PM
thanks for the specs, much appreciated!
Old Dec 19, 2013 | 11:39 PM
any front views of the sides by any chance? want to see how flush the wheels are with the fender and can probably guestimate how low an offset we can go buy with your current setup.... thanks
Old Dec 21, 2013 | 07:04 AM
drksyd's Avatar
It looks good to me. It would look much better with a drop but what can you do when there is none. I believe the offset range is +32 to +40 or so.
Old Dec 21, 2013 | 01:17 PM
Shotgun's Avatar
...To each their own and I agree the look isn't for everyone, but I wanted to post up some pics so that other who might be considering a change have at least something to go off of. I am part of a few different vehicle forums and the people on this site, or should i say this MDX portion, really seem to be more geared toward stock equipment and factory accessories. Not that this is a bad thing, just thought I would throw a little aftermarket into the mix.
I think your ride looks excellent! It's different and adds pizzazz without going over the top for a normally conservative looking vehicle. I applaud and appreciate your effort at sharing something that is unique...
Old Dec 21, 2013 | 05:32 PM
For those who wanted pics from the front and rear.
Old Dec 21, 2013 | 06:09 PM
weather's Avatar
^^^ *sigh* What I'd give to look outside and not see the white $hit we have in Canada....and now under a massive freezing rain storm.
Old Dec 21, 2013 | 08:10 PM
Edward'TLS's Avatar
6G TLX-S
Judging by the front/rear pics, you may run into fender rubbing issue (especially the rear wheels) after you have lowering the MDX.
Old Dec 22, 2013 | 01:24 AM
drksyd's Avatar
Lowering shouldn't be a problem. Only if we had straight axles would rubbing be an issue. What we do have to watch for though is the negative camber.
Old Dec 23, 2013 | 05:20 PM
sbynum's Avatar
No need to drop... Keep it classy...
Old Dec 24, 2013 | 12:52 PM
What size wheels and tires you got on yours?
Old Dec 24, 2013 | 07:12 PM
Here are some better pics after she is all cleaned up.
Old Dec 24, 2013 | 11:52 PM
sbynum's Avatar
Originally Posted by nixonride03
what size wheels and tires you got on yours?
285/35/22
Old Dec 27, 2013 | 10:01 AM
TiggaMan909's Avatar
In Search Of Sunrise....
I like the rim style/design, but 22's is pushing it. 20's will compliment the MDX well!
Old Dec 27, 2013 | 10:03 AM
Originally Posted by sbynum
Very tastefully done! Love the design/style. I personally would have gone an inch smaller!
Old Dec 27, 2013 | 01:22 PM
sbynum's Avatar
Thanks TiggaMan909....
Old Dec 27, 2013 | 10:59 PM
Timmy18's Avatar
Found these online.
Old Dec 28, 2013 | 09:17 AM
sbynum's Avatar
Looks nice in white!
Old Dec 28, 2013 | 06:44 PM
We really wanted a white one...I love the white diamond color...its a shame they dont make it in black interior...that is the only reason I went with graphite luster
Old Dec 28, 2013 | 09:45 PM
kevTL888's Avatar
imo, oversized rims only look good on domestic large SUVs (Tahoe, Escalade, etc)
Old Dec 31, 2013 | 09:43 AM
onefastdoc's Avatar
What kind of wheels are those?
Old Dec 31, 2013 | 08:41 PM
sbynum's Avatar
American Racing multi spoke
Old Jan 2, 2014 | 05:28 PM
hadokenuh's Avatar
What tires are you running? Are there any vibrations at high speed? Looks great!
Old Jan 2, 2014 | 07:28 PM
sbynum's Avatar
Thank you. Tires are Yokohama Prada Spec X. I'm anal about wheel balancing & tire vibration. Pat Goss's garage has a high end wheel balancer that wheel matches, road force balances, fine tune balances and removes $220 from your pockets. Running smooth at all speeds! No vibration.
Old Feb 20, 2014 | 10:06 AM
gtinmia's Avatar
AcuraEnthusiast
Looks good Nixonride03 It's an SUV, it should be fairly high off the ground, especially if you're lugging around a big family. I would not touch the suspension at all!
Old Feb 20, 2014 | 08:33 PM
Majofo's Avatar
Nice.
Exact thoughts.
Old Mar 14, 2014 | 03:18 AM
wokkawokka's Avatar
9th Gear
Are those American Racing wheels 22 X 9….? or 21 X 9…..?
They look good!
Old Mar 14, 2014 | 03:40 AM
wokkawokka's Avatar
9th Gear
Never mind the above post. Tire size answered my question.
Old Mar 17, 2014 | 04:01 PM
wokkawokka's Avatar
9th Gear
What is the exact name of the wheels you got?
American Racing doesn't have wheels like those it seems.
Old Mar 20, 2014 | 07:54 AM
Type34's Avatar
Nice job guys on the 22s. Except for the last-gen Advanced wheel, I've never been a fan of the wheels Acura has fitted any of the MDX gens with. IMO you have to go aftermarket.
Looks good
Old Mar 21, 2014 | 04:23 PM
Sandro's Avatar
great wheels!
