19x8.5 45 ET or 40ET or 35ET or 20ET??
Old Nov 30, 2015 | 08:36 PM
novasteve's Avatar
Talking 19x8.5 45 ET or 40ET or 35ET or 20ET??
Pretty sure I am going to go with these wheels. They are offered in all of these offsets. Which would require the least mods? They are concave style wheels and also wondering which would be the most concave with all things being equal?
I do plan on going with Tein coilovers as well.
2012 Wagon is the car.
Thanks for any help!!
Old Dec 1, 2015 | 10:14 AM
xtcnrice's Avatar
VTEC just kicked in, yo!
Go with the +35. They fit, and will sit a bit more flush than the +45. +20 will not work without either fender work and/or thinner tires.
Old Dec 1, 2015 | 01:37 PM
novasteve's Avatar
Thanks, I appreciate response!
Old Dec 1, 2015 | 10:48 PM
novasteve's Avatar
i plan on doing 235 35 19. Would prefer to do 40, any thoughts?
Will +45 work? Probably need spacers to make flush, correct?
Old Dec 1, 2015 | 10:52 PM
BROlando's Avatar
45 is pretty weak with a 8.5 width. Unless you want to run factory camber out back?
I have +38's with 245/40/18. Natural camber (like -2.5), and they just clear the stock front and rear lips.
Front natural camber is like -0.5 or so.
Old Dec 1, 2015 | 11:33 PM
novasteve's Avatar
What do you mean 'weak'? Not aggressive looking?
I have no problem doing a camber kit as well. I plan on lowering 1.5"-2".
Would like to keep the ride quality good and not go too low.
Old Dec 2, 2015 | 07:31 AM
BROlando's Avatar
The higher the offset, the less agressive the wheel fitment. Meaning that the outboard face of the wheel sits inboard of the fender wall.
*IF* you are buying a camber kit to return to stock settings, and you want to leave your fenders 100% stock, then the +45 will work.
I have 8.5" wide wheels with a +38 offset, and 245/40 tires.
I am also lowered 1.5-2".
My camber ended up around -0.5 front and -2.5 rear.
I did not buy a camber kit. If I adjust my rear camber positive at all...I will have to roll my fender lips so that the tires don't rub on it.
Old Dec 5, 2015 | 06:43 PM
brandonK24's Avatar
6th Gear
Hey man do you know if 19x9.5 +35 will work? Im not lowered as yet. I wanted to do 19x9.5 +45 all around. tires 245/35/19
Old Dec 6, 2015 | 08:39 PM
BROlando's Avatar
Not without fender modification. It will also look awful at stock height.
Old Dec 7, 2015 | 08:29 AM
xtcnrice's Avatar
9.5 +45 worked for me on 235/40r18. 245s? I can't guarantee no rub on the fronts. But 9.5 +35 will rub with those specs for sure. You'll need something less comfy like 225/35r19 for that to work, but like Roland said, it won't look good at stock height.
Good luck.
Old Dec 8, 2015 | 08:11 PM
dave_88's Avatar
Dude
get 245/35/19 or a 40 series.
source: i have 245/35/19
Old Dec 8, 2015 | 10:09 PM
novasteve's Avatar
Any pics? Are you lowered? Will a 40 series fit without rubbing?
Old Dec 9, 2015 | 11:33 AM
BROlando's Avatar
40 series? What width? If you're talking about 245mm width, then 245/40 will be quite a bit taller than a 245/35 (almost 1" taller). They will both be the same width. The width is usually what makes things rub.
The second set of numbers (40, for example) is based on the first set.
245/40 = 245mm wide. 40% of 245mm per sidewall. About 196mm total.
235/35 has 171mm total sidewall.
They're not even close to being a "you can use either" size.
245/40/19 is about 1" taller in diameter than the stock 225/50/17.
Old Dec 9, 2015 | 05:24 PM
novasteve's Avatar
I'm talking about the sidewall. Thinking 235/40/19.
Old Dec 9, 2015 | 06:26 PM
V-tecAc's Avatar
PROFESSIONAL IDIOT
If your a man run 9.5 with a 35 profile tire haha
Old Dec 9, 2015 | 09:14 PM
BROlando's Avatar
Originally Posted by v-tecac
if your a man run 9.5 with a 35 profile tire haha
wat?
Old Dec 12, 2015 | 07:30 PM
KillerG's Avatar
Op is too busy to care
There is a suspension megathread go there and look at the cars and copy someones wheel specs. Simple as fuck.
Old Dec 16, 2015 | 02:25 PM
novasteve's Avatar
Yeah, didn't see anybody running the exact specs I'm thinking of. So, not 'simple as fuck'
Old Dec 23, 2015 | 11:17 PM
dave_88's Avatar
Dude
i posted my car in the wheel set up thread. i don't rub at all but i'm not super dumped on coilovers - just pretty low it gives me just enough problems - since i actually drive my car through the crappy streets of philly.
when i ordered my tires, tirerack actually called me and tried to get me to get a 245/40/19 size instead, but i told them no since it was too tall.
Old Dec 30, 2015 | 11:20 PM
KillerG's Avatar
Mmm... No its genuinely simple. This is a 5 year old+ forum and all of the resources for basic wheel fitment are numerous and plenty. There is an entire subforum hosting years of similar posts and a compiled thread to make it even easier
But you know what youre right you might be the first person to ever run 19x8.5. Should be sick.
Evinac
Dec 16, 2015 01:26 PM
SergeiG
Nov 30, 2015 11:00 PM
SergeiG
Nov 30, 2015 09:04 PM
LaJay007
Nov 30, 2015 08:23 PM
s2000gtx
Nov 30, 2015 01:40 PM
