Tein coil over install help.
I just finish installing all 4 coil over on the car took me basically all day from 8am-4. So finally put tires back on and remove the jack Stan , and it look like the strut is coming up pass the frame of the vehicle 3 out of 4 . So of course I'm like pissed off so I just threw everything in the garage and took a shower . I removed everything from the oem strut and put on the tein coilover like the top hat and a rubber bushing , I don't think I forgot a washer or anything .
Did you double check that you transferred over the stock washers off your oem shocks/springs? They are a gold color and the front 2 are slightly bigger than the rears. I had to use a rubber mallet and hammer them off as they were stuck on there pretty good.
Otacon
Apr 10, 2016 01:56 PM
