P2422 Code - Easiest Fix Ever
Old Jul 22, 2019 | 02:58 PM
stevenjohnmcd's Avatar
I have a 2009 Acura TSX, it threw a P2422 code last week. After looking at this thread, I replaced the control valve under the hood, on the driver's side of the engine. $45. It did not fix the problem. Then I got under the back of the car, pulled one 10mm bolt off the Evap Vent cap, disconnected the main tube going to the cap, and cleaned out the vent. It was packed with old spider webs. Re-installed the evap cap, put it back on the car - fixed. Took 10 minutes. I did not need to waste the $45 for the valve...ping me if you have trouble locating the evap tube and cap - it is super easy to see and take off.
Old Jul 22, 2019 | 06:32 PM
Ron A's Avatar
Administrator
Welcome to the forums.
This post/thread has been moved from the 1G TSX Forum to the model specific forum for better response.
Old Jul 22, 2019 | 06:49 PM
EE4Life's Avatar
Forum Contributor
TSB 08-052 - MIL Comes On With DTC P2422
Applies To: 2009 TSX - ALL
http://www.urvi.net/forumfiles/SB/B08-052.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B08-052.PDF
ALPH4
1G TSX Problems & Fixes
Nov 29, 2021 04:41 PM
damaged442
Sep 15, 2012 02:38 PM
demer11
Aug 14, 2011 08:58 PM
TeknoKing
Aug 5, 2011 01:17 PM
