No start until tapping accelerator
Old Oct 5, 2019 | 10:23 AM
woodywrkng's Avatar
3rd Gear
Greetings folks,
My 2012 TSX Wagon did something quite unusual, and since my knowledge is far more old school, I thought I would run this by you. The car had sat for two days, weather 50 degrees, plenty of battery, it cranked but wouldn't start. Didn't even try to start, just a rapidly spinning starter motor turning over the engine. No check engine light, and no codes according to an Ultra Gauge I have mounted in the car. Not finding a port in the fuel line to check pressure from the pump, I disconnected a line under the hood, wrapped it in a rag, and turned on the key for a second. I could hear the fuel pump and it did indeed pump gas into the rag. Re-connected the fuel line, tried starting again, no luck. Knowing this was the wrong thing to do with a modern drive by wire car, I depressed the gas pedal slightly and cranked the engine. It immediately started, running rich (black smoke from the exhaust) for a second or two. Everything was fine then. The car now starts normally.
Obviously there was un-burned gasoline in the engine when it started, which makes sense I suppose.
Does anyone know what tapping the pedal does while starting? There's no accelerator cable of course, so I'm unsure if the throttle is even opening when I do that. Also, does this engine (2.4l - 4 cyl) have an idle air control valve? I snooped around for one on the car, and unless it's beneath the throttle body I couldn't find one. Looking for the part online draws a blank. I'm aware those can cause issues involving idling and possibly starting.
Thank you.....
Old Oct 5, 2019 | 12:26 PM
more like coincidence.
check the voltage on the battery, most likely the culprit.
if battery checks out good with 12.2-4 volts with the car off, it may be the starter.
Old Oct 5, 2019 | 01:55 PM
woodywrkng's Avatar
3rd Gear
Well, the engine was definitely cranking. As I recall the UltraGauge showed 12.4V with the ignition on, but not engine not running. I did find out these engines don't use an idle air control valve, so that's in the clear. I will keep an eye on the battery voltage as you suggested. It's a three week old Wally World battery so that's certainly suspect. I'm pretty sure it read 11.8V while cranking.
Old Oct 6, 2019 | 11:11 AM
TexasHonda's Avatar
Check that injectors are firing w/ a noid light or feel injectors for vibration. If good check for spark w/ a test light.
good luck
Old Oct 6, 2019 | 02:10 PM
woodywrkng's Avatar
3rd Gear
Will do Tex. I have those things. Thank you.
Old Oct 6, 2019 | 08:27 PM
EuroRspec's Avatar
Sounds like the engine was flooded. By pressing the gas pedal, I believe it stops adding fuel and allows the engine to reset the throttle. If you search, several people have had this happen randomly, most often after a quick start and shut down.
Old Oct 7, 2019 | 11:20 AM
ScottyWM's Avatar
Bonehead
Yep, this has happened to me after a moving the car just a couple feet. Thought what the hell, if I was in my '78 MGB I'd depress the accelerator to the floor to start a flooded engine, and sure enough it worked. Didn't make sense though...
Ralph Young
Sep 1, 2013 08:07 PM
Black Tire
Jan 17, 2010 04:36 PM
Altitude
1G TL Problems & Fixes
Feb 19, 2007 03:21 PM
gsclifton
1G TSX Problems & Fixes
Sep 28, 2004 06:46 PM
Mitchel
Oct 30, 2003 05:44 PM
