Fuel efficiency average 12L/100km?
I get about 10 L/100km on city driving. Note that, when I'm driving in the city, I'm quite consciously looking at the instantaneous L/100km screen to show me where I'm spending most of my "fuel economy" time, and adjusting my pedal travel to try and lower the amount of gas I'm wasting. If you're driving at 50 km/h or less most of the time, you're going to experience terrible fuel economy. I found city roads that have a speed limit of 60 km/h or higher (neglecting hills) to be much more fuel efficient.
Of course I find myself hitting VTEC every other trip so... that might be why my fuel economy hasn't really improved
12L / 100km is 19.6 mpg in 'murican language.
I'm averaging 19.8 mpg which if I'm doing the conversion right is 11.9L/100km. I'm mostly in stop-and-go traffic, but your numbers seem in family.
It could very well be driving style as well. For example, if cars in front of you are just inching forward or maybe a few meters forward but you know (via inspection of the traffic ahead) that they're going to stop again in a few seconds, there is no need to step on the gas just to move forward; let off the brakes and let idle take you forward (assuming you're auto). If you see a traffic light maybe 100m ahead and it's yellow/red, let off the gas (i.e., don't keep gassing it knowing you're going to have to stop anyway). For more pedestrian-like intersections, I try to time it so that by the time it goes green again, I'm still moving so that I don't have to full-stop and start from zero. These simple techniques should save you a bit of gas.
Not saying this is you at all. But, don't be that guy who cuts people off just to slam their brakes and have to stop because of a red light. Using the brakes as little as possible is key.
But with all that being said... K series engines aren't known for great fuel economy. Many have reported great results on the highway, but the city figures aren't the greatest.
Now, how similar are those conditions to *your* or *my* actual driving conditions? I'd bet they're pretty far apart. And that's why we actually see significantly lower figures in real life.
Here's a recent discussion of wagon specific mpgs: https://acurazine.com/forums/second-...n-mpgs-929276/
And for a singular data point, my instant economy readout typically hovers around 18-19 mpg and I manually calculate between 17-19.x. Remember my mileage is nearly all stop and go.
I just did a quick 130+ mile trip, almost all unencumbered highway miles, and it's showing 27.9 mpg. That's the highest I've ever seen and it's because I barely used my brakes for over 2 hours.
I've actually been driving granny style, max 4000 rpm but it is still averaging about 12L or so. Mine is also a sedan if that matters. Ok, as long as it is still considered acceptable then I would be fine.
Wow 12l/100km sounds very steep. I drive mainly rural areas with about 20% city/suburban and am averaging 7.2l/100km on mine. It's a 2010 6 speed 4 cylinder and I am not even that easy on it. 3000rpm changes most of the time with the occasional 4000 and at least 1 5000+rpm 2nd gear pull every day :P will probably hit a 6500rpm pull once every 3 or 4 days just to make sure those high lift lobes get some work!!!
<p>With 20% city those numbers sound right, even if you VTEC once or twice every day or so. I'm doing about 50/50 and getting 9L/100km. I fight between 8.9-9.1 these days, but any extended period of time doing one or the other will obviously steer it in its respective direction. Whereabouts in Ontario do you live and commute? I'm from Toronto, commuting from Scarborough down to Downtown Toronto every morning, and crawling back up every afternoon. If the drive back wasn't so bad, I bet I could do 8L/100km or so!</p>
Totally agree with you and my 2012 does about 21-25 depending on how I drive. Some people accelerate to the red traffic light and then hit the brakes and I always wonder if there is a prize to be won.... Some times I wonder if they are braking and accelerating at the same time!
joflewbyu2
Aug 18, 2019 10:38 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
