engine cranks but won't start
Old May 9, 2016 | 08:53 PM
brocksolid's Avatar
2012 Acura TSX Tech
70,000 kms
It has happened in the past where I don't hold the key long enough to start - the 2nd time I hold it longer and it cranks but won't start. I wait 10 seconds and it works.
Today similar happened, however the 2nd time trying it would not start. I tried at least 5-7 times in a 5 min period and nothing. I left the car for 1 hour and came back. It started right away - however there was a lot of white smoke out of the tail pipe for 5 - 10 seconds. The car currently starts as per usual.
Any ideas?
Researching online points to immobilizer or fuel pump. Both seem too early to go on this age of a vehicle.
Side note: I used a multimeter to confirm both the battery and alternator are good.
Thx!
Old May 10, 2016 | 10:40 AM
brocksolid's Avatar
I can't reproduce it.. From what I have read it could have to do with the immobilizer. I know the dealer gave me a new key when I purchased it. I will try the valet key next time it doesn't start.
Old May 10, 2016 | 10:46 AM
what all did you check using the multimeter? How did you determine your battery was good, because you got a reading? I'd still look into getting a new battery.
Old May 10, 2016 | 11:23 AM
t3hhcaptain's Avatar
Does anything in this thread apply to you? https://acurazine.com/forums/second-...g-over-941552/
Old May 10, 2016 | 12:31 PM
brocksolid's Avatar
Checked the battery cold, and then while running. 12.7 cold and 14.1 running.
Old May 10, 2016 | 12:32 PM
brocksolid's Avatar
some alignment, I will keep this in mind. thank you
gavriil
Aug 20, 2025 04:43 PM
Black Tire
Dec 18, 2017 08:15 AM
marcelft
Mar 28, 2016 09:16 PM
metroboomin
Feb 22, 2016 10:30 PM
GK83
Sep 13, 2014 12:48 AM
