differential fluid
Old Feb 13, 2017 | 12:02 PM
Eve123's Avatar
differential fluid
Does anyone know if in 2013 Acura TSX, the differential fluid needs to be replaced when you're replacing transmission fluid. Is it separate, or is it the same fluid? I was told by one independent mechanic that in some front wheel drive cars, the fluids are separate. So, it the fluid the same or separate in Acura TSX?
Old Feb 13, 2017 | 12:22 PM
Ron A's Avatar
Administrator
Welcome to the forums.
I moved your thread from 4G TL P&F to 2G TSX P&F.
I deleted your other thread since it was an exact duplicate of this one except for the title.
Old Feb 14, 2017 | 08:56 AM
TexasHonda's Avatar
On earlier models (09-10) only ATF is used.
good luck
drakescherer
1G RDX DIY & FAQ
May 9, 2022 04:29 PM
TheMuffinMan
Dec 31, 2016 09:35 PM
Zander
1G RDX (2007-2012)
Dec 21, 2016 02:21 PM
drakeTL
New Member Introductions
Dec 11, 2016 01:24 PM
Reinnie
3G MDX (2014-2020)
Nov 25, 2016 05:39 PM
