2nd oil change
Old Jul 5, 2011 | 10:20 AM
shinyblack's Avatar
2nd oil change
I'm just under 20,000 miles, and I have my 2nd oil change scheduled at the dealership this weekend. The maintenance minder is at 10%, and a reference to B-1. Maintenance B1 suggests an oil change, and a bunch of inspections, as well as a tire rotation. I can get my tires rotated free at a local place. But aside from that, how much does Acura want for a B1 maintenance? I'd surely expect that after only 20k of mostly highway travel, these items should be just fine. My first oil change was free(I had a coupon from the salesman). thanks.
Old Jul 5, 2011 | 10:38 AM
nj2pa2nc's Avatar
it's a car-drive it
since you are getting the tires rotated elsewhere do not ask for the B-1 service. Ask for a oil/filter change. They normally will do an inspection of the car and recommend what they think is needed. If you do not like their suggestions-say NO.
Old Jul 5, 2011 | 03:04 PM
ed_423's Avatar
SeeYou2Crew #2
haha i just got the b1 service reminder 2 days ago!
i havent been to the dealer for almost a year now. they try to rip me off, so i left lol. now i just go to a local mechanic recommended by forum members in the regional section, they are cheap and uses OEM parts and does a great job as well.
i say, try to find another coupon, or look for a GOOD local mechanic (make sure it has good reviews, uses oem parts, etc) because i think the dealer might want to rip you off
Old Jul 5, 2011 | 05:37 PM
nj2pa2nc's Avatar
it's a car-drive it
I have a coupon from a acura dealer-oil/filter change, tire rotation/balance for $49.95.
Old Jul 5, 2011 | 08:33 PM
shinyblack's Avatar
i got the coupon from the salesman when I bought the car...I'll check the dealer's website, but I doubt I'l find anything like the coupon I had for the first change...which was free. So I have not really had much real experience with the service department of the dealer...and frankly, it will probably be the last time I go there, as they are building a brand-new Acura dealer about 4 miles from where I work...all this said, I may just have them do the oil change, and see what kind of courtesy checks they do this time around...
We do also have a pretty reputable Honda dealer near my house, where my wife's Pilot/daugher's Civic is serviced...they've done good work for us in the past, and their prices are relatively competititve...I'd bet they would do maintenance stuff like this on an Acura....so I'll go to the dealership I bought the car from one more time, then move on to my other options....
so i figure an oil change should be around $40/$50, not counting the full B1 service.
Old Jul 5, 2011 | 11:40 PM
09TSXTech's Avatar
B Acura Service Code:
  • Replace Engine Oil
  • Oil Filter
  • Drain Plug Washer
  • Service Front and Rear Brakes and Check Thickness
  • Check Pads and Rotors
  • Check Calipers
  • Check Parking Brake Adjustment
  • Inspect Tie-Rod Ends & Steering Gear Box/Bolts
  • Check Rack Grease and Steering Linkage
  • Check Boots for Damage and Leaking Grease
  • Check Fluid Lines for Damage and Leaks
  • Lube Door Locks and Seals
  • Inspect Suspension Components
  • Check Bolts for Tightness
  • Check Ball Joint Boots
  • Inspect Driveshaft Boots
  • Inspect Brake Hoses and Lines
  • Check Master Cylinder and ABS Modulator
  • Inspect all Fluids (Transmission, Power Steering, Brake, Engine Coolant)
  • Inspect Exhaust System
  • Check Catalytic Converter Heat Shields & Exhaust Pipes & Muffler
  • Inspect Fuel Lines and Connections
  • Test Battery
  • Reset Maintenance Minder
Old Jul 8, 2011 | 04:52 PM
pinatubo's Avatar
Does local mechanic shop do all that? or they just change oil and rotate tires?
Old Jul 9, 2011 | 07:55 AM
gwickes's Avatar
Even though the mileage minder doesn't indicate a "2" in the code as well, you might consider changing out the cabin air filter (5 -10 minute job) and engine air filter (another 5 -10 minute job) as well. At your mileage, it's a good time to change them out... or at least look at them. Total cost for both filters from a local auto store will run you around $40 -$50
Old Jul 10, 2011 | 10:12 PM
shinyblack's Avatar
yes, I was thinking the same thing about maybe changing out both the air and cabin filters. Ive only owned the car for a little over a year(bought it in April 2010)
mada51589
Jan 9, 2025 04:40 PM
robm
Sep 18, 2015 07:53 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
