issues from LED interior light replacement???
Old Apr 26, 2016 | 07:57 PM
mikeyfinesse's Avatar
5th Gear
Exclamation issues from LED interior light replacement???
I bought some LED replacement lights for my 2010 TSX and when I was replacing the dome map lights in the front, I put in the driver side light fine and after struggling to try to put in the passenger side light i heard a noise (kind of like a short circuit or something like that). after that noise the both dome map lights won't turn on(front and back), the doors won't lock if i try to use the key fob to lock them and the rear door lights that light up the floor won't turn on. What can i do to fix this? I don't know if it would be the fuse or something else that i could have messed up during installation. I apologize if somebody had posted a question like this before I'm new to here and i tried to use the search feature but didn't find anything. Also this is my first car and i don't have much experience dealing with cars. Thanks for you help in advance!!!
Old Apr 26, 2016 | 08:02 PM
5th Gear
i have a 2.4l base 2010 tsx incase anyone needed that info to help answer my question
Old Apr 26, 2016 | 08:59 PM
thunderbt3's Avatar
Is your blinker fluid full? If they are full, you might need to replace the entire wiring harness...
Old Apr 26, 2016 | 09:01 PM
Check all your fuses
Old Apr 26, 2016 | 09:03 PM
5th Gear
im not dumb enough to check for blinker fluid lol.
Old Apr 26, 2016 | 09:05 PM
5th Gear
if i check my fuses and i find a broken fuse then will fixing that fuse or fuses be the fix? another user mentioned a wiring harness
Old Apr 27, 2016 | 01:39 PM
5th Gear
Thanks a lot guys!! i checked the user manual for the fuse for interior lighting. i replaced it and everything works now. Any tips on installing the LED's? maybe i did something wrong? i had the light on while installing it. could that be the issue? thanks for your help again
Old Apr 27, 2016 | 02:25 PM
keep the lights off so you don't short anything
Old May 3, 2016 | 09:21 AM
icu2tsx's Avatar
rule of thumb when working with electrical components, disconnect the battery.
Old May 10, 2016 | 10:36 AM
cu2wagon's Avatar
Yeah, the general rule of thumb is to disconnect the battery before replacing the light bulbs.
Seems silly.
I always thought so too.
But so many people have had this exact problem when replacing the lights for LEDs.
So it might be a good idea.
But I still don't do it.
Because YOLO.
And because...
HondaGuy21
1G RDX Problems & Fixes
Jul 13, 2016 04:20 PM
