I bought some LED replacement lights for my 2010 TSX and when I was replacing the dome map lights in the front, I put in the driver side light fine and after struggling to try to put in the passenger side light i heard a noise (kind of like a short circuit or something like that). after that noise the both dome map lights won't turn on(front and back), the doors won't lock if i try to use the key fob to lock them and the rear door lights that light up the floor won't turn on. What can i do to fix this? I don't know if it would be the fuse or something else that i could have messed up during installation. I apologize if somebody had posted a question like this before I'm new to here and i tried to use the search feature but didn't find anything. Also this is my first car and i don't have much experience dealing with cars. Thanks for you help in advance!!!
Thanks a lot guys!! i checked the user manual for the fuse for interior lighting. i replaced it and everything works now. Any tips on installing the LED's? maybe i did something wrong? i had the light on while installing it. could that be the issue? thanks for your help again
rule of thumb when working with electrical components, disconnect the battery.
