Trying to find the perfect LED reverse bulbs
Old Feb 3, 2016 | 01:12 AM
alexbenz's Avatar
so i put in some spare cree led's and they were lighting up the whole backyard so i put in some 68 led's , these
2X 7443 7440 6000K Xenon White Backup Reverse 68 LED SMD Lights Bulbs | eBay
They seem a tad bit dimmer than the stock bulbs.
Today i got these in cause they looked to be dimmer than the first set if cree bulbs i got but nope....Super bright. I don't want to blind people at night.
http://www.ebay.com/itm/261580828557?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
So now my question is what am i left with? I want something 6000k in color but brighter than stock bulbs but not bright like the cree's
Old Feb 5, 2016 | 09:59 PM
Harper's Avatar
Unregistered Member
They're reverse lights, used to light up shit behind you so you can see at night. Unless you drive in reverse all night I can't figure out why you want dimmer bulbs.
Old Feb 5, 2016 | 10:02 PM
cu2wagon's Avatar
Yeah, I want to know more about the first ones.
I wouldn't mind setting dry grass aflame with super bright reverse lights.
Old Feb 8, 2016 | 02:23 PM
alexbenz's Avatar
Yes true in some ways but i also don't want to blind people behind me if i'm trying to parallel park or what not
Old Feb 8, 2016 | 06:19 PM
RTM's Avatar
RTM
Yeah, my truck back up lights are much more effective than the TSX lights, would love something brighter. Lighting the dry grass.... Now we are talking. Those behind should know not to stare into the sun.
Old Feb 8, 2016 | 09:09 PM
Harper's Avatar
Unregistered Member
^ exactly, bright ass backup lights all the way.
Edit:
Philips 921 White Vision LED Back-up light (Pack of 2) https://www.amazon.com/dp/B00P2D41OQ..._dIvUwbYZHWZ08
These bulbs are supposed to light up dry, ahem, grass...
Old Feb 9, 2016 | 12:07 PM
RTM's Avatar
RTM
Ordered myself some of the Cree 7440 for my 2012. If you hear of lots of grass fires in the SF Bay area, could be me.
For $16 I got the bulbs, plus 10 marker lights for my truck. They are just starting to go out again. I suspect changing the bulbs will be a bigger PITA than ordering them was.
Old Feb 10, 2016 | 08:44 AM
Username 0's Avatar
I like cars.
I learned my lesson on buying leds bulbs on ebay. its a hit or miss and most of the time its a miss with bulbs dying weeks after installing. Since I installed my euro rear fog lamp, I only have one reverse lamp. I bought the brightest 7443/7440 white bulb VLEDS had to offer at the time. Its so bright that they only suggest it for reverse use or the warranty will be voided. Two of these together would be nice and bright.
5K WHITE HIGH OUTPUT 21 LED BACK-UP LIGHT 7440 1000LM | 1 EACH - 7443 - 7440 LED - Shop Bulb #
Old Feb 10, 2016 | 02:24 PM
soupi's Avatar
can you post pictureS?
Old Feb 10, 2016 | 07:43 PM
Username 0's Avatar
I like cars.
The camera was having a hard time picking up how bright this bulb is. Just one is brighter then two halogen and comes with warranty.
Old Feb 14, 2016 | 02:11 PM
Eggs999bacon's Avatar
Are these hard to install? They are pricey but not having a back up camera with 20% tints is hard, so was looking into these. I assume they are just plug and play, and do i need to remove a lot of screws and what not to get into the housing?
Old Feb 15, 2016 | 02:21 PM
RTM's Avatar
RTM
On the drivers side, two plastic snaps hold the trunk liner in place. On the passengers, only one, but its a bit tighter cuz something else is bolted down.
Bulbs pop in real easy. (Twist and pull out. Slide in, then twist to install)
Hardest part was getting the little plastic snaps back in place correct.
10 minutes total, including taking pictures of the brightness. Other pics of the garage door don't show any real difference, I was too far away. The brake lights are still brighter than the back up lights, but it is a help
New one on the Drivers Side
Old Feb 15, 2016 | 02:56 PM
Username 0's Avatar
I like cars.
Yeah. Very easy to install.
Old Feb 28, 2016 | 12:38 PM
Edit:
I know this late, but I checked those bulbs on amazon with the "fit my car" option, and it says it does not it the TSX. I would like these as the price is a lot better than vleds, but wasn't sure how accurate amazon was.
Old Feb 28, 2016 | 01:36 PM
What bulbs does your TSX take? Compare them
FYI 921 and 168 are the same socket just different wattages, maybe that's why Amazon says it it won't fit
Old Mar 1, 2016 | 10:06 PM
According to what I researched, the back up light is a 7440. So, neither of what you mentioned. Do you think a 921 would fit? if so, id rather save $40 and go with the philips rather than vleds.
Old Mar 1, 2016 | 10:26 PM
cu2wagon's Avatar
Probably not easily.
According to this lookup, the rear turn signal on the sedan is a 921. You can see if they'll physically fit, but I think the power draw is likely different between the 921 and 7440. Dimensions look obviously wrong:
921:
7440:
Old Mar 2, 2016 | 07:42 AM
921:
7440:
Thanks for this! Looks like I will need to go the vled route. It is either vleds, or several hundred dollars for a double din + back up camera set up.
Old Mar 2, 2016 | 07:51 AM
No, 7440 won't fly unfortunately. :soory: I was speaking from my TL's experience where the bulb was a 921. I believe 921 draws more than 168 and 7440 draws more than 921, they are not compatible though.
Old Mar 2, 2016 | 09:19 AM
Username 0's Avatar
I like cars.
You can also find some quality bulbs on Amazon. You can pick them from customer reviews, pictures, questions and some of them come with warranty.
Old Mar 5, 2016 | 08:26 PM
Acuradaze's Avatar
4th Gear
i dont mean to hijack the topic but would any of these LED lights listed above fit a 2010 v6 tsx? I'm looking for some good quality, bright LED reverse bulbs since i have tinted windows and it can be difficult to see at night and i dont want to get rid of the tints. i currently have the stock lights in.
Old Mar 5, 2016 | 11:26 PM
Username 0's Avatar
I like cars.
Yes. All the bulbs are the same regardless of the motor type.
