Trunk sub install wiring?
Old Oct 29, 2013 | 12:08 AM
iCrap's Avatar
TSX AMG Type //M i-VVT
I have an opportunity to get a decent sub for cheap... my only problem with this is how to run the wiring.
I would need to run a wire from the battery to the trunk.... how difficult is this on the TSX? And i assume i would just take the input off the stock sub and feed it into my new amp for the new sub?
Old Oct 29, 2013 | 03:59 PM
D4nnyD's Avatar
Depending on how much power your amp requires it can either be easy or hard. If 4 gauge wire will suffice you can run it through a pre existing grommet on the front wall above the steering wheel.
If your amp supports high level inputs then all you need to do is feed the two wires that go into your stock subwoofer to your amp. Make sure you know which is positive and negative. If not you will need a hi/lo convertor (same as line in convertor) and then use rcas to feed the signal to your amp.
There are already a couple threads with this info for a basic aftermarket sub install.
Old Oct 30, 2013 | 09:09 AM
skathe's Avatar
he nailed it, splice your remote into a power wire that turns on only when the car is on also, generally via ignition or fuse box for lights.
Old Oct 30, 2013 | 09:14 AM
I told you this, yesterday....iCrap.
Old Oct 30, 2013 | 10:43 AM
iCrap's Avatar
Yeah i know. this was posted before you answered.
Old Oct 30, 2013 | 10:45 AM
ohhh! lol, well then, carry on!
cycdaniel
Dec 17, 2019 10:58 AM
spoiler900
May 25, 2016 10:16 PM
EE4Life
Sep 11, 2015 10:13 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
alan_rich
Sep 7, 2015 11:08 PM
