Sound dampening (dynamat)
A few things to consider;
http://www.hometheaterhifi.com/volum...ng-6-2003.html
On the other hand, if you have a tech , then I'm not quite sure how the ASC work or if sound deadening would have any effect on the system.
There is also the school of thought that placing a small(6x6) square of sound damening material on a panel is sufficient to disrupt any vibrations from the panel - this is what most manufacturers do.
Graphite Ghost
they sell door 'KITS'.
you will want to put some on the inner door skin once the panel is removed. you will also want to put some on the inside of the outer panel where you can get it in there.
to help with more bass you can SEAL some of the bigger holes in that inner with some plexi. need to be removeable you ever have a window issue.
IMO you can definitely do this yourself, maybe not to the UMPTH degree but IMO it doesent take much to improve over stock in all sorts of areas.
i used b-quiet.com. i bought a bunch from eBay cheaper than new.
and a cheap wall paper roller. def helped/
Can someone here intelligently discuss the Active Sound Control and identify which cars it is in? I've heard everything from V6 to tech package to neither.
In short, ASC uses a microphone to pick up "steady" noise (like engine drone) and produces a harmonic to cancel out that drone.
While we know that the microphone is in the cabin, and the system uses the regular speakers to create the cancelling noise, what I don't know is if dampening the door panels would interfere with that.
Informative stuff. I may read this very seriously when I put in some exhaust work If I run into drone. Thanks guys.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
