rear deck speakers polarity
Old Apr 14, 2014 | 05:29 PM
shawnamin's Avatar
ShawnAmin
Whats up guys i was just wondering if anyone knows which wires are positive and negative on our rear deck speakers. The left speakers has a yellow wire and a brown wire both wires have silver stripes, and the right speaker has a blue wire and an orange wire both wires have silver stripes. Im trying to tap the wires to install a LOC... and yes i know i could tap the subwoofer ive done that but i wanna see how it sounds with the rear deck speakers tapped cause it sucks the way it is right now.
Old Apr 14, 2014 | 05:56 PM
iCrap's Avatar
TSX AMG Type //M i-VVT
lol aren't you the guy who put stick on hood vents?
Old Apr 14, 2014 | 08:09 PM
shawnamin's Avatar
ShawnAmin
hmmm, What gave it away...
Old Apr 14, 2014 | 09:36 PM
iCrap's Avatar
how much HP do they add?
Old Apr 15, 2014 | 06:22 AM
iSeeYouTwo's Avatar
Please don't splice any OEM wiring - use these instead:
They're like $6 a pair.
Old Apr 15, 2014 | 05:21 PM
skathe's Avatar
if i knew these had existed................
Old Apr 15, 2014 | 09:46 PM
shawnamin's Avatar
ShawnAmin
exactly how i feel
Old Apr 15, 2014 | 10:47 PM
iCrap's Avatar
maybe put some hood vents stickers on your subwoofer? it might sound better
Old Apr 16, 2014 | 08:05 AM
BlackNsexy2010's Avatar
https://www.dropbox.com/s/d42qaou8bv...ing%202012.pdf
Old Apr 16, 2014 | 08:07 AM
also.. you can do the battery test to determine polarity..i guess this may be difficult with a cover over the speaker.. i tried it with tweeters and a D battery and it worked
Old Apr 17, 2014 | 04:47 AM
Toolgurl22's Avatar
Looking for factory Sub 3G
I'm looking to keep all of my factory stereo but my Sub is blown. I can't find a stock replacement. Any help would be appreciated. I already have a JL fabricated in the trunk but I want all 8 of my speakers working again.
Old Apr 17, 2014 | 07:52 AM
can u snap up a pic of the jl? just curious to see what it looks like.. the enclosure not the actual sub lol
Old Apr 17, 2014 | 09:19 AM
skathe's Avatar
whats with the trolling?
Old Apr 18, 2014 | 12:02 AM
shawnamin's Avatar
ShawnAmin
Dont stress to much about the factory sub if you already got an aftermarket, i dont think its worth replacing it. Im not sure how this would sound but maybe even remove the stock sub and that way you have a little port for your aftermarket subwoofer.
Old Apr 18, 2014 | 11:23 AM
iCrap's Avatar
What? Hood vents improve everything.
Old Apr 18, 2014 | 03:58 PM
musty hustla's Avatar
Chill out, there is some useful info in this thread.
Old Apr 19, 2014 | 03:11 PM
shawnamin's Avatar
ShawnAmin
So i tapped into the rear deck speakers but my subwoofer wasnt getting any sound, i did the battery test so i know the wires were all right, and i was under the impression the rear decks only put out bass, i guess not, im back to how i had it before now tapped into the subwoofer, I was messing around and i tried to play a 40hz test tone to tune the subwoofer with and i noticed there was no sound coming from the sub, so im assuming that our subs dont get freq's that low. Anyone have any ideas what freq it does play and if there is anything i can do to make the sub sound better ie get those lows. I cant really afford one of those 800 DSP either.
Old May 10, 2014 | 05:01 AM
Why do u have a PA system.. Or does that mean polk audio?
And aside from using a processor idk how else you can do that..or new headunit .. Our amp does the processing.. And I would assume the lowest notes get sent to the sub. so if the sub tap isn't working for u then those r the two best options I can think of..
I know for me I upgraded my ground and power and sanded down my ground connection.. This improved the output.. Mine was taken from the sub.. Now I have a DSP and there is a noticeable difference
Old May 12, 2014 | 09:11 AM
shawnamin's Avatar
ShawnAmin
I got everything working, i tapped the rear deck instead of the factory subwoofer, i had to use a lot of bass boost on the amp and turn the gains up but it sounds noticeably better. Took it to the shop they tuned it. And yes i have a Public Address system in my car, just for shits and giggles.
Feb 25, 2020 09:57 AM
akbears15
15
Nov 5, 2015 07:06 AM
Dunnik
Sep 15, 2015 11:52 PM
Pegon95
Sep 15, 2015 01:54 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
