No audio '09 Tech
Old Feb 6, 2013 | 03:33 PM
Bunkie111's Avatar
2009 Acura TSX
No audio '09 Tech
So after a week after the dealer replaced my battery, I have no sound. The system, Navi included, is working, everything lights up and appears to be playing, but no sound from any of the speakers. Here's what I have done to troubleshoot:
Fuses:
Tested #15 under the hood, #18 on Driver's and #15 on passengers (amp). The manual doesn't label these very well, but I know that the amp fuse is correct as that one is labeled in the manual, under the hood was correct as after I pulled it, I had to enter in radio/Navi codes. Just not sure about #18 on Drivers.
Battery:
Disconnected the cables, entered codes, no sound.
Called the Dealer:
Asked me if the vehicle had a mute button. Really?
Navi:
Popped the disc out for Ha Has. Read on another forum that a bad disc could cause problems.
Anyone have any thoughts? Is there something simple I am overlooking?
Thanks!
Old Feb 7, 2013 | 06:48 AM
musty hustla's Avatar
Do the radio, bluetooth audio, or USB audio work? Can you hear phone calls?
If only the nav system, there is a menu to adjust the volume of the navigation prompts.
Visit the dealer Bunk
Old Feb 7, 2013 | 07:53 AM
Bunkie111's Avatar
2009 Acura TSX
Everything works, just no sound from the speakers.
Old Feb 7, 2013 | 11:22 AM
So you're saying sounds comes out the radio (FM/USB/XM)?
Do you get the beep or "say a command" when you hit the talk button?
If so I think the volume in the nav is turned down.
Old Feb 7, 2013 | 01:33 PM
Bunkie111's Avatar
2009 Acura TSX
No. No sound coming from anything. No beeps from the bluetooth. Everything appears functional, just no sound whatsover.
Old Feb 7, 2013 | 05:33 PM
Bunkie111's Avatar
2009 Acura TSX
Update: realized that my seat memory is not working as well. Checked that fuse and replaced it even though it's good and it doesn't work along with the sound. Looks like it's off to the Dealer I go
Old Feb 7, 2013 | 08:09 PM
mellostack's Avatar
CU2 TSXClass
I was going to tell you that off the back... It could be your car amp located in your truck
Old Feb 7, 2013 | 08:16 PM
mellostack's Avatar
CU2 TSXClass
it looks something like this, i removed mines because i added music to my car already
Old Feb 8, 2013 | 07:38 AM
Bunkie111's Avatar
2009 Acura TSX
I read in another thread that the stock amp is behind the carpet trim on the right side of the trunk. I pulled away some of the trim to have a peak, but didn't see it. Is that the correct location?
Old Feb 8, 2013 | 05:23 PM
mellostack's Avatar
CU2 TSXClass
yeah is on top of you rear right side wheel make sure u have a flash light because it is really car you will get the idea when u open that up
Old Feb 10, 2013 | 11:03 AM
Bunkie111's Avatar
2009 Acura TSX
Oddly enough, the sound just came back on out of nowhere. The seat memory is still out, but I wonder if there is short or something. I will see what the dealer says.
Old Feb 10, 2013 | 03:14 PM
mellostack's Avatar
CU2 TSXClass
yeah just take it to the dealer let them deal with that... they are not suppose to charge you for that..
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
