iPhone 6 and 2010 TSX Bluetooth - Not working
Old Sep 28, 2014 | 06:05 PM
TSXSam's Avatar
8th Gear
Hey all,
I upgraded my phone to the iPhone 6, and ever since I did....the bluetooth has not worked.
I have narrowed it to being something with the phone itself as I used my 5S with iOS on the car without any problems. So now I am lost in wonder.
Have any of you gotten an iPhone 6 to work on the car yet? If so, any tricks you found in the process?
Thank you in advance!
Old Sep 28, 2014 | 07:29 PM
urbanstereo's Avatar
i use my 5S with iOS 8.0.2 fine right now.
can you connect other bluetooth devices to it fine?
Old Sep 28, 2014 | 09:30 PM
ceb's Avatar
ceb
The 6 works fine in my sister's 2013.
Try deleting all phones from your car, delete all cars from your phone and then reboot your phone. Turn your car off, start it up and try pairing it again.
Old Sep 29, 2014 | 03:46 PM
Terdbath's Avatar
What ceb says.
I had a problem with my Iphone 6 and bluetooth syncing up at first. After deleting all the phones from the car then repairing it works every time.
Old Sep 30, 2014 | 08:16 AM
gammonTSX's Avatar
I am having the exact same problem with My 2010 TSX and Iphone 6...how do you delete phones from the car? I'm not showing any possible connection when i search on the phone for the car's bluetooth.
Old Sep 30, 2014 | 12:19 PM
aerospike's Avatar
i think you'll have to clear all the info/data for your HFL.
aerospike's Avatar
Link -> https://acurazine.com/forums/audio-bluetooth-electronics-navigation-304/delete-all-paired-phones-733994/
Old Oct 2, 2014 | 09:53 PM
26Shaun's Avatar
iOS 8 Causing Widespread Bluetooth Connectivity Issues in Cars - Mac Rumors
Old Oct 3, 2014 | 06:29 AM
ceb's Avatar
ceb
This makes Windows look real good. Hell, it even makes the Blackberry Playbook look good.
Apple's claim to fame was that everything worked as intended and you could customize your phone/iPad many ways without breaking anything. That clearly no longer applies.
Old Oct 9, 2014 | 09:10 PM
TSXSam's Avatar
8th Gear
Update: I got on the phone with Apple, and the tech suggested the following which WORKED! See below:
1) Take the phone back to factory settings (in iTunes I backed up my phone and did a restore).
2) Then I removed all phones previously paired to the car.
3) Then pair the phone when it is in its factory state
4) Delete the phone I just paired back to where there are no phones paired.
5) Restore the back up I just made to my phone from iTunes.
6) Once all loaded up, pair the phone to the car.
That's it. It worked for me. Unfortunately I had to re-log into all my apps that are on my phone, even though they came from the restored back-up.
Hope this helps.
Old Oct 13, 2014 | 05:25 PM
Prototype's Avatar
My iPhone 6 is integrating better than my iPhone 5 and my wife's iPhone 5s in her '10 TSX tech. I think about it now and it's integrating better in my '13 Accord as well.
Old Nov 25, 2014 | 06:38 PM
got an iphone 6 and had issues pairing it. after removing my old phone from the car, i was able to add it.
Old Dec 2, 2014 | 08:54 AM
icu2tsx's Avatar
iphone 6+ here, didn't have any issues(09 non tech) only thing I did do was to remove my old iphone from the HFL first then paired the new one.
Old Mar 14, 2015 | 02:47 AM
GioPR's Avatar
Your Mom
Im Having this same problem and nothing has worked for me
Old May 24, 2015 | 11:51 AM
Babyboi's Avatar
5th Gear
Hope this helps.
damn, i'm sure this took some time to do!
Old Aug 4, 2015 | 03:10 PM
Acurafab's Avatar
iPhone 5 problems
Hello. After reading the thread I wanted to know if anyone was having similar problems. I have a 2011 Acura TSX and an iPhone 5. The phone will connect via Bluetooth no problem and play music from the Bluetooth as well. However when I answer or make phone calls via the car the person on the other line hears a loud ringing noise the entire time. Does anyone have a solution for this? Thank you.
Rocktman1
Oct 31, 2015 02:33 PM
acurajj
Sep 19, 2015 03:47 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
jordanboi
Sep 5, 2015 01:33 AM
