Iphone 4 problems....
Old Jan 26, 2011 | 12:57 AM
SinCityTLX's Avatar
when you start the car it takes about 2 minutes to make the connection. If you are on a call before turning the car on, when it does connect it has a loud static sound for about 10-12 seconds and you are unable to communicate until after this static attack consummates.
The connection is also not always reliable, sometimes it won't connect at all.
Old Feb 10, 2011 | 09:42 PM
jason1245's Avatar
the iphone 4 uses bt version v2.1 with a2dp which is the exact same as iphone 3gs. Bluetooth issues isnt a common problem with the iphone 4. Delete the phone out of bluetooth options in the car. Then do a 2 button reset on the iphone. Hold both power button and home buttom for 25 secs or until the phone boots off the resets and shows an apple logo. Pair the phone again and see if it helps. Hope this works!
Old Feb 19, 2011 | 01:03 AM
SinCityTLX's Avatar
reset everything and it still has the same problems. My lexus bluetooth was flawless, this one is very tempermental.
Old Feb 19, 2011 | 12:42 PM
TSXKid2010's Avatar
SEEYOU2CREW
My TSX with my iPhone 4 works flawless
None of those problems. By the time I turn my car on and pull my phone out to put it into that space on the door, phone is already connected.
Old Feb 25, 2011 | 10:52 PM
PyroDave's Avatar
this happens with my verizon blackberry bold actually. my old bold used to pair pretty quickly. but it did have that 5-10 second buzzing sound if i was on a call, very annoying. this one can take up to 5-10 min to connect, i even turn the bluetooth off and then on again on the phone. gonna activate my new bold that i got replaced through warranty tonight. we'll see how it is tomorrow. this doesn't bold well though, im gonna get the verizon iphone 4 soon
Old Mar 23, 2011 | 06:33 AM
Euronoob's Avatar
With the iPhone, you can't press 'Next' with your dash/steering wheel right?
Old Mar 28, 2011 | 03:49 PM
chilimost's Avatar
As of IOS4, you can use the dash/steering wheel controls for track forward/rewind skipping via bluetooth.
Old Mar 30, 2011 | 02:05 PM
PyroDave's Avatar
you can use the steering wheel to change songs, sometimes it doesn't work though. i have times where bluetooth instantly connects, while other times i go to settings on my iphone and click on. iphone 4 + non tech 2010 tsx are not a match made in heaven, but work well enough
Old Mar 30, 2011 | 02:12 PM
TRIUMPHT's Avatar
the issues i notice with my iphone 4 in the car is when i have it on bluetooth and using the ipod if i make/answer a call when i am done with the call the music doesn't play i have to unplug it and plug it back in...............but only when i have bluetooth connected ..........
Old Mar 30, 2011 | 08:57 PM
PyroDave's Avatar
triumpht you mean the music from the iphone stops streaming through the bluetooth after a call? i've had the same thing. if that happens, click the ipod icon, and go to now playing. next to the right arrow to switch the song, theres a weird looking icon. click it and make sure hands free link is selected instead of iphone. dkwhy b it switches that setting
Old Mar 30, 2011 | 09:12 PM
TSXKid2010's Avatar
SEEYOU2CREW
I have none of these problems with my iPhone 4 o-o
Are you guys jailbroken?
Old Apr 1, 2011 | 08:59 PM
PyroDave's Avatar
negative. verizon iphone, straight from the store. for some reason when my bluetooth is connected, and i get a call, it defaults the audio source to the phone. i have to touch the button to change it to hands free link. other timnes it'll go straight to the car, and the music wont be interupted
mlody
Dec 4, 2019 02:11 PM
rockyboy
Sep 25, 2015 10:44 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
Barb Jackson
Sep 15, 2015 02:27 PM
IndycarFaster
Sep 11, 2015 02:52 PM
