I-009: Any way to get video to run on tech pkg?
Old Apr 5, 2010 | 09:33 PM
BlackMagicTSX's Avatar
I was trying to figure if anyone has tried to get video to run on the navi throug aux or anyway? Thanks guys!
Old Apr 6, 2010 | 04:34 PM
lopez205tx's Avatar
yeah i was thinking about this. i thought about tapping into the reverse cam. and adding bluetooth audio.
Old Apr 6, 2010 | 04:37 PM
GrigioX's Avatar
mine has bluetooth audio...
Old Apr 6, 2010 | 04:52 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
You have to get a separate DVD player and a video to nav converter, such as NavTool, or Dom's unit.
Old Apr 6, 2010 | 05:03 PM
lopez205tx's Avatar
yeah mine does to but i mean sending the audio via bluetooth, thats my project for the month. or going in threw aux. input
Old Apr 8, 2010 | 06:49 PM
Jonnie5's Avatar
If u guys can get this up and running, u mind doing a write up, or like wut did u buy? im really interested in this
Old Apr 19, 2010 | 07:05 PM
MittaBoolay's Avatar
3rd Gear
Check out avelectronic.com or email Sam- sales@avelectronic.com I was just emailing him about the exact same thing.. he was telling me that they should be coming out with a digital mobile tv tuner next month. You will be able to watch tv,dvd,have ipod interface and backup camera all on your stock navi. Im holding out for that. Its all pug and play too.
Old May 7, 2010 | 03:47 PM
fceeviper's Avatar
Self Aware
Any updates on this?
Old May 23, 2010 | 06:40 PM
lemmingboy's Avatar
I think figured out how to do this without spending $300+. It really doesn't seem hard to do, I just need some help finding connectors.
The output of the nav system to the screen is RGB w/a combined sync signal so my plan is to start with a laptop with VGA output. VGA is an RGB signal but has separate channels for the horizontal and vertical sync. To go from VGA to RGBS, you need to go from 6 wires (R,G,B,HS,VS,Gnd) down to 5 wires (R,G,B,S,Gnd) but splicing HS and VS together will not work.
I think there are two options to get the right signal- first is to buy a pre-made convertor, the second is to wire your own. The cheapest convertor I have found on eBay is $35 and it requires 5 V power, which would be a pain to provide, but definitely feasible. For the second option, I found this circuit diagram which is really simple and could be built for pennies, but I have no clue if it would work. Either way, the signal processing seems easy to do.
http://www.nexusuk.org/projects/vga2scart/circuit
The problem I have is tapping into the car. I know where the connectors are and I have the pinouts showing the locations of R, G, B, S, and GND.
The easy connector to find is the one going into the back of the nav unit- it is a JAE MX34 series 32 pin connector. There are a handful of suppliers who will sell them individually. It is really accessible in the trunk, but I don't want to run a cable all the way up to the front of the car.
The next connector in the harness is right above the shin of the front seat passenger (underneath the kick plate). It's easy to get to as well and would be preferable to tap into since it is already up front. All I know is that it is a 34 pin connection. I have pictures of the connector, can anyone find a manufacturer or part #s? I have no intention of cutting wires on the OEM harness, so I am looking for the actual connectors. I'm willing to swap information on where to buy them for a pin-out of both the front and rear connectors.
Thanks,
Old May 24, 2010 | 05:48 PM
slden's Avatar
This scheme will work:
We made custom connectors (for DVD Navi):
Old May 24, 2010 | 09:15 PM
civichbdx's Avatar
I wan't in on this. how much?
Old May 25, 2010 | 02:39 PM
bjohnston115's Avatar
pics are not working. What are they of? I would love to do this mod/get my hands on those connectors at minimal cost.
Old May 29, 2010 | 08:39 PM
lopez205tx's Avatar
check this out
I think this will work
https://acurazine.com/forums/showthr...t=362179&pp=25
Old Jun 4, 2010 | 09:00 PM
lopez205tx's Avatar
Old Jun 4, 2010 | 10:26 PM
baltimorecaesar's Avatar
can you confirm this works, and also does anyone know the screen resolution?
jamestheunderdog
Jul 19, 2016 07:58 PM
Shank009
Sep 17, 2015 12:53 AM
Barb Jackson
Sep 15, 2015 02:27 PM
spoiler900
Sep 10, 2015 01:06 PM
Aug 30, 2015 02:39 PM
