HID Fogs don't turn on
Old Jan 21, 2012 | 10:46 AM
hjahmad's Avatar
Before i put in HIDs for my fogs, i had a pair of LEDs which worked perfectly till the bulb broke in half due to poor build quality. But i never had this problem.
The HIDs don't always turn on when the car is started, i have to cycle the fog light switch to cut the power, then turn it on and the lights will turn on. kind of annoying. anyone else notice this with their aftermarket HID fogs?
I partly blame acura for this. though i am sure the aftermarket HID kits don't have the highest standard of quality. the issue i see is that the car leaves uses the low beams and fog lights for the pathway lighting when you unlock the car. and then you turn the ignition, the power to the lights are cut once or twice. and then turn on full once the car is on. this is probably not good for any of the bulbs or ballasts. the low beams can handle the quick power switching, but the fogs usually go out. sometimes only 1, sometimes both. and i have to cycle the power to turn it back on.
probably not a big issue, but an annoying one.
Old Jan 21, 2012 | 11:21 AM
ceb's Avatar
ceb
So you are blaming Acura for you using low quality aftermarket crap?
If everything works as intended when using OE parts then it certainly is not even remotely Acura's fault.
Old Jan 22, 2012 | 11:26 AM
hjahmad's Avatar
haha yes
still annoying though
Old Jan 22, 2012 | 11:44 AM
benben01's Avatar
I suggest you run a separate wiring harness for the HID fogs. The OEM 10amp fuse rating for each fog is borderline. The other option is to make sure you turn off your fogs when you turn off your engine to avoid this quick on and off flickering...
Old Jan 22, 2012 | 02:42 PM
ed_423's Avatar
SeeYou2Crew #2
are you sayin that when you turn the car on your lights flickered and the fogs turn off? if so, try to not leave your lights in auto. turn the car on, then turn on the lights manually.
Old Jan 23, 2012 | 09:00 PM
TSXKid2010's Avatar
SEEYOU2CREW
I have the EXACT same problem. Everytime I get in my car, turn it on, flash the high beams once or twice. it's become routine to me.
Old Jan 24, 2012 | 07:31 AM
hjahmad's Avatar
yeah i hate it
there is no pattern for which bulb doesnt turn on, sometimes both, sometimes just one and i feel like a dope.
all that flickering cant be good for the bulbs or ballast
Old Feb 6, 2012 | 03:21 AM
sonu_7's Avatar
i get the same problem
Old Dec 6, 2013 | 01:47 AM
Tsx780's Avatar
I'm running 15 fuse with no problems
Old Dec 6, 2013 | 08:31 AM
mrstak's Avatar
7# werC 2uoYeeS
thank you for necroposting. please keep doing it. we love reading year old threads.
Old Dec 6, 2013 | 08:35 AM
plus, putting a bigger fuse is not advised.
the wiring can only handle so much, by putting a bigger fuse, you run the chance of something catching on fire.
the proper way is to run a relay wire, which allows enough watts to pass through to power the fogs
Old Dec 6, 2013 | 10:34 AM
ceb's Avatar
ceb
Darwin approves of using larger fuses than the wiring is designed for.
The wire overheats, the fuse doesn't blow and the car catches fire, turning the driver into a crispy critter - one more fool off the road.
Old Dec 9, 2013 | 03:29 PM
speedracer_2020's Avatar
Same issues here. I'll have 1 of the two lights survive the start-up... but... too get the other one back on, I'll have to turn off the fogs and turn 'em back on again. I got two years out of my aftermarket kit -- running the headlights all day and all night with many many startups.
Old Dec 9, 2013 | 03:46 PM
mrCHOW's Avatar
everyone that is having this issue, use relays to fix and also suggest getting quality bulbs and ballasts. UV Coated bulbs will protect the chrome reflectors from peeling. I get all my bulbs and ballasts from www.theretrofitsource.com
pozebly
Sep 23, 2015 07:30 AM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
