Compustar Remote Start Installed
Old Jan 5, 2013 | 05:11 PM
JR_Rider's Avatar
I just had a Compustar remote start system installed in my car and am very impressed. I would recommend that anybody looking into security systems or remote start systems go with Compustar products. The customizability is excellent and the range on this basic system is great.
Old Jan 5, 2013 | 10:15 PM
musty hustla's Avatar
Does the car stay running when you open the door?
Old Jan 9, 2013 | 07:43 AM
JR_Rider's Avatar
Yup, it sure does. If you get in the car and turn the key to the #2 position you can drive off without ever having to stop and restart the car again.
Old Jan 9, 2013 | 09:56 AM
KillerG's Avatar
Op is too busy to care
info? pics? price? remote? features? price? and how much was your install?
Old Jan 9, 2013 | 10:11 AM
JR_Rider's Avatar
This is a Compustar remote start system CS601-S w/ 1-Button Starter Combo. The kit came with 2 one button remotes that work up to 800 feet away from the vehicle. There is an antenna mounted inside the car, next to the rearview mirror mount. We also need the Blade unit to communicate with the car's computer and allow the car to start w/o having to give up a key. I purchased this as a Groupon and the remote start installed was $199 and I paid an additional $125 for the blade.
Old Jan 9, 2013 | 11:33 AM
KillerG's Avatar
so all together was only 325? that's pretty great. to do list for after warranty goes out
Old Jan 9, 2013 | 03:06 PM
JR_Rider's Avatar
Yup, that's correct. Initially I was planning to add the Drone system on here as well so that I can control everything from my iPhone but since the 1 button already has the range I wanted I don't know if I want to spend $350 to have the novelty of controlling the system from my phone. You can also add EZgo to the system which adds a proximity sensor so the doors will lock and unlock when you get within 5 feet of the vehicle, similar to the "Keyless Go", "Smart Key" and "Intelligent Key" features on other cars.
Old Jan 10, 2013 | 12:14 PM
KillerG's Avatar
I think it will be worth it just to hear the exhaust flair up from the outside. Is compustar a well reputed brand? first ive heard of them
Old Jan 10, 2013 | 05:47 PM
drivedata's Avatar
Membered Register
yes they are they have been around for a while
Old Jan 10, 2013 | 06:46 PM
JR_Rider's Avatar
Compustar is the best in the business. Call around to a few install shops. Initially I was looking at Viper but upon doing some research I found that Compustar products are more reliable with a lower failure rate and their warranty replacement process is much simpler than DEIs(Viper).
Old Jan 10, 2013 | 09:44 PM
BaoZZeR's Avatar
lol your avatar displays your bad parking. I wanted the viper smart phone kit. but then someone told me if you lose your phone you lose your car.... I've never lost my phone before but i hope this doesn't happen to me if I do decide to go that route. Considering a push start system!!!
Old Jan 10, 2013 | 10:25 PM
JR_Rider's Avatar
Never thought about it like that but that's probably true. I don't lose phones either so I shouldn't have that problem. I was looking at the smart start as well and found accompany that wanted $370 installed for the smart start remote start. I decided to pass on the Viper solution after doing that research though.
Old Jan 11, 2013 | 08:20 AM
bjwsan's Avatar
??? Looks pretty straight to me... if you're commenting on not centered, nice to stay as far away from the $%# door dingers as possible...
VERY interested in this mod! Was the Groupon a local install shop? What was standard price?
Old Jan 11, 2013 | 05:18 PM
JR_Rider's Avatar
I thought I parked pretty straight too! Lol. I spent $200 to have the door dings pulled from my 2006 TSX and decided this go round to try and avoid as many dings as possible. This was done by a local shop in Raleigh, 919 Motoring. The normal price was $370 I believe, plus the drone unit, which is $125.
Old Jan 16, 2013 | 02:49 AM
BaoZZeR's Avatar
It's just that he's parked on the "You can't drive on this" part of the road. IDK what's it called.
<----- FL DRIVER!
Old Jan 20, 2013 | 04:02 PM
flanders43's Avatar
I also have a compustar with drone best setup and have my factory key setup to set aftermarket alarm and remote start if anyone wants specs I can give them to you I got a smoking deal on everything only reason I went with the drone also
Old Jan 23, 2013 | 10:30 AM
rnc_forever's Avatar
Rice and Crackers...
Flanders - Can you elaborate? I've been told that using the factory key fob is not possible. Which is why I have been looking at the Smart Start system.
Is it only compustart systems that let you use the factory keyfob to remote start?
Does installng any remote start void my factory warranty?
Old Feb 9, 2013 | 11:27 AM
audioillusionsinc's Avatar
6th Gear
glad to see the compustar worked out for you buddy
Old Feb 9, 2013 | 05:09 PM
JR_Rider's Avatar
You can use the factory remote if you add EZ Go to the Compustar system. EZ Go is a proximity sensor setup that locks and unlocks the vehicle when you are within 5 feet. It also allows you to use the factory remote to start the car. The only issue with relying on the key is that the range is limited by the range of the factory remote. This doesn't affect your warranty at all.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
jordanboi
Sep 5, 2015 01:33 AM
datadr
Sep 2, 2015 06:46 PM
